**new Warcraft Patch 1.21**
WarDynasty
HWLuxx SC2-Champ, HWLuxx SC2-Cup2 Master#1
Wien
Neuerdings ist ja der Patch 1.21 herausgekommen, aber was hat sich verändert?? Hab bis jetzt noch nichts gemerkt Oo:(
Omfg,nach dem Patch,da gibts doch son Button "Änderungen anzeigen" :hmm:
Wer lesen kann...
Und für alle anderen:
Nur Bugfixing,nix neues.
ich denk da sind 2 neue maps drinne?
Ja... -.-
Wo nur?Nach dem patchen gibts den.2 Stück,einmal Quit und einmal für die Änderungen.Die Readme sozusagen.
Fixed a timing problem with the game on PCs with dual-core CPUs. Fixed a crash that could occur with the Frost Breath ability. Fixed a crash that could happen in multiplayer games. Fixed an exploit that could happen in multiplayer games
für all diejenigen, die nicht selber dazu in der lage sind die patch.txt im installationsverzeichnis zu öffnen und zu lesen:
("neuerungen" fett hervorgehoben)
WARCRAFT III: THE FROZEN THRONE VERSION HISTORY
Patch 1.21
FEATURES
- The game now runs natively on both PowerPC-based and Intel-based Macs.
- Player can now view frames per second using the "/fps" chat command.
FIXES
- Fixed a timing problem with the game on PCs with dual-core CPUs.
- Fixed a crash that could occur with the Frost Breath ability.
- Fixed a crash that could happen in multiplayer games.
- Fixed an exploit that could happen in multiplayer games.
Important Note on Patching for Mac Players: The file layout inside the
game folder is changed significantly by Patch 1.21. As a result, in order
to be able to install the Frozen Throne expansion from CD, you must
install Reign of Chaos first, then install Frozen Throne from CD, and then
patch to version 1.21, in that order. If you patch to v1.21 and then
attempt to install Frozen Throne after that, it will not install
correctly.
MAPS
- New maps:
- (2)SecretValley
- (6)BomberCommand
- (4)LostTemple (RoC)
- The 4 Forest Troll Berserkers by the natural expansions now drop Level
2 Permanent instead of Level 2 Charged items
- (4)TurtleRock
- The 4 Ogre Warriors along the outer pathways now drop Level 2
- (6)GnollWood
- The 4 Gnoll Brutes by the central Item Shops now drop Level 2
na super neuer patch und ich darf wc wieder neu installieren weil ich windoof des öfteren übergebügelt hab kennt da einer nen tip wie ich patches installiert bekomm ohne gleich das ganze game neu zu installieren?
Also bei mir hat es ihn aut. installiert...:)
ich finde die sollten Secret Valley auch dem Laddermappool hinzufügen wenn sie im neuen Patch schon "offiziell" dabei is, immerhin gehört die Map seit langem zum Standardreportoire bei allen wichtigen Ligen/Turnieren.
y, find ich auch, obwohl man könnte auch ein paar Maps abschaffen...
Die wichtigste Änderung dürfte wohl sein, dass es keine Lightning Shields mehr bei den leichten Creepspots gibt. Dürfte die Humans freuen.
Aber sonst hätten se ja auch nicht viel Patchen können, das Spiel ist ja total gebalanced.
Ja....
Aber wenn du Win neudraufhaust,hast du keine Registryeinträge mehr.Das Spiel funktioniert dann noch,lässt sich aber nicht mehr Patchen.Alles klar soweit? :d
Und du wolltest n Proclan aufmachen.Hf :hmm:
Ja....
hab nie was anderes gesagt...
