Hallo
Es scheint so, daß der aufgetauchte Treiber leider nur eine Zwischenlösung ist. Hoffentlich kriegen die es bei Silicon Image recht schnell hin das Problem zu lösen, ohne daß die Performance leidet
SiI3112A: nForce RAID 0 Data Corruption
April 24, 2003
At this time we are aware of the issue and are working with nVidia to develop a solution to this data corruption problem. Some of the motherboard suppliers may have posted an SiI3112A driver on their websites, but it needs to be clarified that those drivers were intended to be an interim solution that just prevents the data corruption from occurring. There is a significant trade-off in performance when using these drivers so it is not likely to be the final solution.
As soon as nVidia and Silicon Image have an acceptable solution to the issue, we will post it on our websites as well as provide it to our motherboard customers for posting.
Thank you for your understanding.
mfG,
bc
April 24, 2003
mfG,
bc
