Hi, ich will mir in nächster Zeit zum Studieren ein Notebook kaufen.
Dabei bin ich auf das IBM ThinkPad T43 2668 gestoßen (s.u.)
Der Preis liegt bei SFR 2.300,-- bzw. EUR 1.500,--.
Jetzt meine Frage an euch: Lohnt sich der Kauf bzw. welche Alternativen gibt es?
thx Raffi
Main Specifications
Product Description IBM ThinkPad T43 2668 - Pentium M 750 1.86 GHz - 14.1" TFT
Manufacturer Warranty 3 years warranty
Dimensions (WxDxH) 31.1 cm x 25.5 cm x 3.1 cm
Weight 2.5 kg
Processor Intel Pentium M 750 1.86 GHz
Hard Drive 60 GB
Networking Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Power AC 110/230 V (50/60 Hz)
RAM 512 MB (installed) / 2 GB (max) - DDR II SDRAM - PC2-4200 - 533 MHz
Graphics Controller ATI MOBILITY RADEON X300 - 64 MB
Audio Output Sound card
Localisation German / Germany
Cache Memory 2 MB - L2 Cache
Optical Storage DVD-RAM / DVD-RW - plug-in module
Display 14.1" TFT active matrix SXGA+ (1400 x 1050)
Telecom Fax / modem - CDC - 56 Kbps
Input Device Keyboard, TrackPoint, UltraNav
Battery Lithium Ion
Average Run Time 3.6 hour(s)
Operating System Microsoft Windows XP Professional
Built-in Devices Stereo speakers, wireless LAN aerial, fingerprint reader, ThinkLight
System Type Notebook
Mobile Technology Intel Centrino
Wireless NIC Intel PRO/Wireless 2915ABG
Operating System / Software
OS Provided Microsoft Windows XP Professional
Software Adobe Acrobat Reader, PC Doctor, Intervideo WinDVD, IBM Access Connections, IBM Secure Client, Access IBM, IBM RecordNow, InterVideo WinDVD Creator, IBM Drive Letter Access, IBM Rescue and Recovery with Rapid Restore, Norton AntiVirus 2005 (OEM) with 3 months updates
Battery
Technology Lithium Ion
Installed Qty 1 / 2 (max)
Capacity 4400 mAh
Telecom
Features V.92 upgradable
Max Transfer Rate 56 Kbps
Protocols & Specifications ITU V.90
Modem Fax / modem - CDC
Input Device(s)
Type Keyboard, TrackPoint, UltraNav
Optical Storage
Type DVD-RAM / DVD-RW - plug-in module
Cache Memory
Type L2 Cache
Installed Size 2 MB
Display
Display Type 14.1" TFT active matrix
Max Resolution 1400 x 1050
Audio
Compliant Standards DirectSound, AC '97
Audio Input Microphone
Audio Codec AD1981B
Video
Video Memory DDR SDRAM - 64 MB
Max Resolution (external) 2048 x 1536 / 24-bit (16.7 million colours)
Graphics Processor /
Vendor ATI MOBILITY RADEON X300 - PCI Express x16
Environmental Parameters
Sound Emission 34 dB
Min Operating Temperature 5 °C
Max Operating Temperature 31.3 °C
Humidity Range Operating 8 - 95%
Power
Power Device External
Voltage Required AC 110/230 V (50/60 Hz)
Miscellaneous
Features Locking device keyhole (cable lock), administrator password, hard drive password, power-on password, IBM Embedded Security Subsystem 2.0, IBM Active Protection System
Compliant Standards ACPI 2.0, ACPI 1.0b, CE, MPR II, BSMI, cUL, EPA Energy Star, NOM, VCCI-II, UL 60950, CB, FCC Part 15 B, CCC, MIC
Networking
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IrDA 1.1, Wi-Fi CERTIFIED
Remote Management Protocol DMI 2.0, CIM
Storage
Hard Drive 60 GB
Storage Controller IDE
RAM
Technology DDR II SDRAM - 533 MHz
Installed Size 512 MB / 2 GB (max)
Memory Specification Compliance PC2-4200
Processor
Features Enhanced SpeedStep technology, Execute Disable Bit capability
Chipset Type Mobile Intel 915PM Express
Data Bus Speed 533 MHz
General
Width 31.1 cm
Depth 25.5 cm
Height 3.1 cm
Weight 2.5 kg
thx Raffi
Main Specifications
Weight 2.5 kg
Hard Drive 60 GB
Battery Lithium Ion
Battery
Capacity 4400 mAh
Telecom
Input Device(s)
Optical Storage
Cache Memory
Type L2 Cache
Installed Size 2 MB
Display
Audio
Audio Codec AD1981B
Video
Power
Miscellaneous
Networking
Storage
Hard Drive 60 GB
RAM
Processor
General
Width 31.1 cm
Depth 25.5 cm
Height 3.1 cm
Weight 2.5 kg
