ODroid C2 .... der neue 4K Player ?
pumuckel
Urgestein
Bayern
.. Schon gesehen ?
* Amlogic ARM® Cortex®-A53(ARMv8) 2Ghz quad core CPUs*
* Mali™-450 GPU (3 Pixel-processors + 2 Vertex shader processors)
* 2Gbyte DDR3 SDRAM
* Gigabit Ethernet
* HDMI 2.0 4K/60Hz display
* H.265 4K/60FPS and H.264 4K/30FPS capable VPU
* 40pin GPIOs + 7pin I2S
* eMMC5.0 HS400 Flash Storage slot / UHS-1 SDR50 MicroSD Card slot
* USB 2.0 Host x 4, USB OTG x 1 (power + data capable)
* Infrared(IR) Receiver
* Ubuntu 16.04 or Android 5.1 Lollipop based on Kernel 3.14LTS
ODROID | Hardkernel
... Mit HDMI 2.0 :)
... IR scheint gleich zum C1/c1+
Beachten :
* ARM 64bit is a very new platform and some system specific Linux softwares are not working stably at this moment.*
** So there might be the compatibility issues frequently and we may need longer time to fix the issues.
* Ubuntu 16.04 LTS is also on the alpha stage and it causes the instability and incompatibility problems.
Mehr Infos : http://forum.odroid.com/
klingt gut :)
Ob der DTS-HD Bitstream packt?
Das hat mich bisher vom Pi abgehalten...
