Mhh okay ... also ich habe noch einen BR-Recorder an SATA 3 und einen DVD Recorder an SATA 4 mit denen habe ich gar keine Probleme ...
Hier mal mein System im Überblick:
Property Value
Manufacturer ASUSTeK Computer INC.
Model P5N-E SLI
Version 1.XX
Serial Number 123456789000
North Bridge NVIDIA nForce 650i SLI SPP Revision A2
South Bridge NVIDIA nForce 650i SLI MCP Revision A2
CPU Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
Cpu Socket Socket 775 LGA
System Slots 5 PCI
Memory Summary
Maximum Capacity 128 MBytes
Maximum Memory Module Size 32 MBytes
Memory Slots 4
Error Correction None
Property Value
BIOS Vendor Phoenix Technologies, LTD
BIOS Version ASUS P5N-E SLI ACPI BIOS Revision 1404
BIOS Date 08/05/2009
BIOS Size 512 KB
BIOS Starting Segment E000h
DMI Version 2.4
Characteristics - supports PCI
- supports Plug-and-Play
- supports APM
- upgradeable (Flash) BIOS
- allows BIOS shadowing
- supports booting from CD-ROM
- supports selectable boot
- BIOS ROM is socketed
- supports Enhanced Disk Drive specification
- supports INT 13 5.25-inch/360K floppy services
- supports INT 13 5.25-inch/1.2M floppy services
- supports INT 13 3.5-inch/720K floppy services
- supports INT 13 3.5-inch/2.88M floppy services
- supports INT 05 print-screen
- supports INT 09 and 8042 keyboard services
- supports INT 14 serial services
- supports INT 17 printer services
- supports INT 10 CGA/Mono video services
- supports ACPI
- supports legacy USB
- supports booting from LS-120
- supports booting from ATAPI ZIP drive
- BIOS Boot Specification supported
- Enable Targeted Content Distribution
Property Value
Number of CPU(s) One Physical Processor / 2 Cores / 2 Logical Processors / 64 bits
CPU Full Name Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
CPU Name Intel Core 2 Duo E7400
CPU Code Name Wolfdale
Platform Name Socket 775 LGA
Revision R0
Technology 45 nm
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, ET64, XD, EST
Original Clock 2800 MHz
Original System Clock 266 MHz
Original Multiplier 10.6
CPU Clock 2807 MHz
System Clock 266.7 MHz
FSB 1066.8 MHz
Core 0 Speed 2800.4 MHz
Core 0 Multiplier 10.5
Core 1 Speed 2800.4 MHz
Core 1 Multiplier 10.5
L1 Data Cache 2 x 32 KBytes
L1 Instructions Cache 2 x 32 KBytes
L2 Cache 3072 KBytes
Property Value
HEY-NET-DESK1
Memory Summary
Memory Slots 4
DRAM Frequency 266.7 MHz
Memory Timings 4-4-4-31 (CL-RCD-RP-RAS)
Device Locator Slot 1
Part Number SUPERTALENT
Serial Number 004B004D
Capacity 1024 MBytes
Memory Type DDR2 (PC2-5300)
Speed 333 MHz (DDR2 667)
Supported Frequencies 200.0 MHz, 266.7 MHz, 333.3 MHz
Memory Timings 3-3-3-8-11 at 200.0 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Memory Timings 4-4-4-11-15 at 266.7 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Memory Timings 5-5-5-13-18 at 333.3 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Data Width 64 bits
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 2
Manufacturer Nanya Technology
Part Number NT1GT64U88D0BY-AD
Serial Number C70A0544
Memory Type DDR2 (PC2-6400)
Speed 400 MHz (DDR2 800)
Supported Frequencies 266.7 MHz, 333.3 MHz, 400.0 MHz
Memory Timings 4-4-4-12-16 at 266.7 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Memory Timings 5-5-5-15-20 at 333.3 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Memory Timings 6-6-6-18-24 at 400.0 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Data Width 64 bits
Manufacturing Date 2009, Week 18
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 3
Manufacturer Kingston
Part Number 99U5230-008.A00LF
Serial Number 3F244343
Memory Type DDR2 (PC2-4300)
Speed 266 MHz (DDR2 533)
Supported Frequencies 200.0 MHz, 266.7 MHz, 266.7 MHz
Memory Timings 3-3-3-9-12 at 200.0 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Memory Timings 5-4-4-12-16 at 266.7 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC)
Data Width 64 bits
Manufacturing Date 2007, Week 26
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 4
Serial Number 3F244243
Data Width 64 bits
EPP SPD Support No
XMP SPD Support No
Sensor Value Min Max
HEY-NET-DESK1
ITE IT87
Voltages
CPU VCORE 1.23 V 1.23 V 1.28 V
+3.3V 3.34 V 3.33 V 3.34 V
+5V 4.97 V 4.97 V 5.00 V
+12V 12.10 V 12.03 V 12.10 V
+5V VCCH 5.00 V 5.00 V 5.00 V
VBAT 3.14 V 3.14 V 3.14 V
Temperatures
TMPIN0 36 °C (96 °F) 36 °C (96 °F) 36 °C (96 °F)
TMPIN1 31 °C (87 °F) 31 °C (87 °F) 31 °C (87 °F)
TMPIN2 25 °C (76 °F) 25 °C (76 °F) 25 °C (76 °F)
Fans
FANIN0 806 RPM 801 RPM 807 RPM
FANIN1 932 RPM 931 RPM 932 RPM
ACPI
Temperatures
THRM 40 °C (103 °F) 40 °C (103 °F) 40 °C (103 °F)
Temperatures
Core #0 37 °C (98 °F) 37 °C (98 °F) 42 °C (107 °F)
Core #1 37 °C (98 °F) 37 °C (98 °F) 39 °C (102 °F)
ASUS EAH5750 Series
Temperatures
GPU Core 38 °C (100 °F) 37 °C (98 °F) 38 °C (100 °F)
ASUS EAH5750 Series
Temperatures
ST3250820A
Temperatures
HDD 29 °C (84 °F) 29 °C (84 °F) 29 °C (84 °F)
SAMSUNG HD753LJ
Temperatures
HDD 20 °C (67 °F) 20 °C (67 °F) 20 °C (67 °F)
SAMSUNG HD753LJ
Temperatures
SAMSUNG HD753LJ
Temperatures
SAMSUNG HD753LJ
Temperatures
Mir fällt gerade auf das mein RAM ja schon was zusammengeproscht ist was die Taktfrequenzen usw angeht ...
Kann mir jemand sagen was ich bzw wie ich am besten bestücken soll !?
also mit 4Gb wollte ich schon belegen!!
