Also Danke Leute,
insbes. Bucho!!!
hier ist das Ergebnis:
Number of processors 1
Number of cores 1 per processor
Number of threads 1 (max 1) per processor
Name Intel Pentium III E
Code Name Coppermine
Specification
Package Slot 1 SECC2
Family/Model/Stepping 6.8.3
Extended Family/Model 6.8
Brand ID 2
Core Stepping cB0
Technology 0.18 um
Core Speed 701.6 MHz
Multiplier x Bus speed 7.0 x 100.2 MHz
Stock frequency 700 MHz
Instruction sets MMX, SSE
L1 Data cache 16 KBytes, 4-way set associative, 32-byte line size
L1 Instruction cache 16 KBytes, 4-way set associative, 32-byte line size
L2 cache 256 KBytes, 8-way set associative, 32-byte line size
Chipset & Memory
Northbridge Intel i440BX/ZX rev. B1
Southbridge Intel 82371EB/MB (PIIX4E/M) rev. 02
Graphic Interface AGP
AGP Revision 1.0
AGP Transfer Rate 2x
AGP Side Band Addressing not supported, not enabled
Memory Type SDRAM
Memory Size 512 MBytes
Memory Frequency 100.2 MHz (1:1)
CAS# Latency (tCL) 2.0 clocks
RAS# to CAS# (tRDC) 2 clocks
RAS# Precharge (tRP) 2 clocks
DRAM Idle Timer 32 clocks
System
System Manufacturer MICRO-STAR INTERNATIONAL CO., LTD
System Name MS-6119
System S/N
Mainboard Vendor MICRO-STAR INTERNATIONAL CO., LTD
Mainboard Model MS-6119 (i440BX)
BIOS Vendor Award Software International, Inc.
BIOS Version 4.51 PG
BIOS Date 08/03/00
Memory SPD
Module 1 SDRAM, PC133 (133 MHz), 256 MBytes, Samsung
Module 2 SDRAM, PC133 (133 MHz), 256 MBytes, Samsung
Heißen diese Zahlen,
"""Memory Frequency 100.2 MHz (1:1)
RAS# Precharge (tRP) 2 clocks"""
dass ich die Timing von 3 auf 2 richtig eingestellt habe???
gruss
paxus
