PCI-E flexible Gen 3.0 riser card VS. PCI-E flexible Gen 2.0 riser card
a1684901
Taiwan
There are a lot of cable on the market
But many do not use
Will not even boot
Especially to PCIE3.0 environment
[Test System]
Test environment ︰ PCIE 3.0 environment
Test items︰
1.Test with PCI Express Gen2.0 X16 to X16 175mm。
2.Test with PCI Express Gen3.0 X16 to X16 200mm。
3.Test without PCIe riser cable card 。
CPU︰I5-3470 。
MB︰JW B75-ITX。
GPU︰ PowerColor R9-270X 。
SSD︰DATA SP900 128G。
D-RAM︰Kingston 2G X2 。
Case︰Li Heat Industries Limited. ITX 12 cubic liters 。
Power︰TFX-450W。
OS: Windows 8.1
LL
LL
LL
LL
Score︰As you can see in these photos, I've started my computer, but it shows a black screen.
LL
LL
LL
As you can see in the GPU-Z picture, it shows that it is running in PCI-E 3.0 X16 @ X16 3.0
Score︰P7394
Score︰P7369 and P7361
[The results]
The second generation of PCI Express X16 Gen 2.0 175 mm
Score ︰Unable to start running
The second generation of PCI Express X16 Gen 3.0 200 mm
Score ︰P7394
If you do not use the lift cable
(Why test with cable scores high than without cable?
Because it will not be the same scores at different times. It will between about 72XX~73XX. So actully. it dosen't mean that the scores with cable is higher .)
