Hi
Habe ein problem : Habe irgentwie mist gebaut und jetzt findet perl die ordner nicht richtig o.s.ä.
apt-get -f install :
Was kann ich da machen?
Code:
debconf: Perl may be unconfigured (Can't locate Debconf/Log.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
Setting up libc6 (2.10.2-6) ...
Can't locate Debconf/Db.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at /usr/share/debconf/frontend line 6.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing libc6 (--configure):
subprocess post-installation script returned error exit status 2
Errors were encountered while processing:
libc6
E: Sub-process /usr/bin/dpkg returned an error code (1)
