PHPNews ist sehr leistungsfähig
PHP News script -Software.
<?php
error_reporting (E_ALL ^ E_NOTICE);
* | Archive.php | *
* PHPNews - 1.3.0 Release *
* Open Source Project started by Pierce Ward *
* Software Distributed at: *
PHPNews - News Management Software *
* (c) 2003, 2005 Pierce Ward (Big P) *
* All rights reserved. *
* This program has been written under the *
* terms of the GNU General Public Licence as *
* published by the Free Software Foundation. *
* The GNU GPL can be found in gpl.txt *
/* Get the absolute path */
$path = __FILE__;
$path = str_replace('archive.php', '', $path);
include($path . 'settings.php');
/* Don't edit - Connects to DB */
$dbcon = mysql_connect($db_server, $db_user, $db_passwd);
mysql_select_db($db_name);
/* Grabs Settings and puts it in an Array */
$result = mysql_query('SELECT variable,value FROM ' . $db_prefix . 'settings');
$dbQueries++;
$Settings = array();
while ($row = mysql_fetch_array($result))
$Settings[$row[0]] = $row[1];
/* Include The Language File */
$lang = $Settings['language'];
if(!file_exists($path . 'languages/' . $lang . '.news.lng'))
include_once($path . 'languages/en_GB.news.lng');
setlocale(LC_TIME, $lang);
else
include_once($path . 'languages/' . $lang . '.news.lng');
$language = $lng;
Archive Functions
You can call each function by its name, eg.
<? byMonth(); ?>
You can only call either byMonth(); or byCat();
not both in the same page.
/* Display News in Archive by Month/Year */
function byMonth()
global $Settings, $language, $path, $_SERVER, $db_prefix;
/* Order the news by Month/Year */
if (!$_GET['month'] && !$_GET['year'])
$SQL_query = mysql_query('SELECT DISTINCT month,year FROM ' . $db_prefix . 'news ORDER by id DESC');
while ($arc = mysql_fetch_assoc($SQL_query))
/* Get the total number of posts per month */
$total = mysql_query('SELECT count(*) as total FROM ' . $db_prefix . 'news WHERE month = \'' . $arc['month'] . '\' AND year = \'' . $arc['year'] . '\'');
$var = mysql_fetch_assoc($total);
/* Set up Variables for Template */
$month = strftime('%B', mktime(0, 0, 0, $arc['month'], 1, 0));
$year = $arc['year'];
$numPosts = $var['total'];
$url = $_SERVER['PHP_SELF'];
include($path . 'templates/date_temp.php');
/* Display links to the articles */
else if (isset($_GET['month']) && isset($_GET['year']))
$SQL_query = mysql_query('SELECT n.id,n.posterid,n.postername,n.subject,n.time,p.username,p.email'
. ' FROM ' . $db_prefix . 'news AS n'
. ' LEFT JOIN ' . $db_prefix . 'posters AS p ON(n.posterid=p.id)'
. ' WHERE month=\'' . $_GET['month']. '\' AND year=\'' . $_GET['year'] . '\''
. ' AND n.trusted = 1'
. ' ORDER by n.id DESC');
while ($posts = mysql_fetch_assoc($SQL_query))
/* Set up easy variables */
$url = $Settings['siteurl'];
$id = $posts['id'];
$subject = stripslashes($posts['subject']);
$username = $posts['username'];
$time = strftime($Settings['shorttimeformat'], $posts['time']);
if (!$username)
$username = $posts['postername'];
if ($posts['email'] != '')
$username = '<a href="mailto:' . $posts['email'] . '">' . $username . '</a>';
else
$username = $username;
include($path . 'templates/link_temp.php');
/* Otherwise, something went wrong, so print out an error message */
else
echo '<b>' , $language['CONTENT_ERROR'] , '</b>: ' , $language['CONTENT_ERRORREQUIREDVARIABLE'];
/* Display News in Archive ordered by Categories */
function byCat()
/* Sort News by Categories */
if (!$_GET['cat'])
$SQL_query = mysql_query('SELECT DISTINCT * FROM ' . $db_prefix . 'categories ORDER by id ASC');
while ($cat = mysql_fetch_assoc($SQL_query))
$catid = $cat['id'];
$category = $cat['catname'];
if ($cat['caticon'] != '')
$caticon = '<img src="' . $cat['caticon'] . '" border="0" alt="' . $category . '">';
else
$caticon = '';
include($path . 'templates/cat_temp.php');
/* Sort News by month, with News from selected Category only */
else if (isset($_GET['cat']) && !isset($_GET['month']) && !isset($_GET['year']))
$total = mysql_query('SELECT count(*) as total FROM ' . $db_prefix . 'news WHERE catid = \'' . $_GET['cat'] . '\' AND month=\'' . $cat['month'] . '\' AND year=\'' . $cat['year'] . '\'');
/* Set up easy Variables */
$month = strftime('%B', mktime(0, 0, 0, $cat['month'], 1, 0));
$year = $cat['year'];
$catid = $_GET['cat'];
include($path . 'templates/catdate_temp.php');
/* Display the news links from the Category */
else if (isset($_GET['cat']) && isset($_GET['month']) && isset($_GET['year']))
. ' WHERE catid=\'' . $_GET['cat'] . '\' AND month=\'' . $_GET['month']. '\' AND year=\'' . $_GET['year'] . '\''
$id = $posts['id'];
$username = $row['username'];
if (!$username)
if ($row['email'] != '')
$username = '<a href="mailto:' . $row['email'] . '">' . $username . '</a>';
else
else
