Prey---->LÄUFT NICHT!
Scrj256
Hi, der Titel sagt eig schon alles, Meine Hardware ist dreimal so gut wie erfordert:fresse: Oder vielleicht 2mal zuviel??? Das System Seht ihr in meiner Sig. Habe den neusten Graka Treiber gesaugt den(163.71_forceware_winxp_32bit_international_whql) Den neusten Prey Patch(DH-Patch-2007-01-29-13117-final2) Es kommt immer folgende Meldung:
Prey 1.3.117 win-x86 Jan 11 2007 15:20:10
1863 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & x64
2048 MB System Memory
320 MB Video Memory
Winsock Initialized
Found interface: {740D61CE-3468-4174-9F88-71063E4DAAC3} Realtek RTL8169/8110 Family Gigabit Ethernet NIC - Paketplaner-Miniport - 192.168.0.3/255.255.255.0
Sys_InitNetworking: adding loopback interface
prey using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 I:\Programme\Prey\base\game00.pk4 with checksum 0xff851bf2
Loaded pk4 I:\Programme\Prey\base\game02.pk4 with checksum 0xaa46eb08
Loaded pk4 I:\Programme\Prey\base\pak000.pk4 with checksum 0x7dc00ede
Loaded pk4 I:\Programme\Prey\base\pak001.pk4 with checksum 0xd06647b1
Loaded pk4 I:\Programme\Prey\base\pak002.pk4 with checksum 0x57dce443
Loaded pk4 I:\Programme\Prey\base\pak003.pk4 with checksum 0x263006fe
Loaded pk4 I:\Programme\Prey\base\pak004.pk4 with checksum 0xcc075380
Loaded pk4 I:\Programme\Prey\base\pak005.pk4 with checksum 0xead35190
Loaded pk4 I:\Programme\Prey\base\pak006.pk4 with checksum 0xed8ce397
Loaded pk4 I:\Programme\Prey\base\pak020.pk4 with checksum 0x39191193
Current search path:
I:\Programme\Prey/base
I:\Programme\Prey\base\pak020.pk4 (23 files)
I:\Programme\Prey\base\pak006.pk4 (108 files)
I:\Programme\Prey\base\pak005.pk4 (10 files)
I:\Programme\Prey\base\pak004.pk4 (3739 files)
I:\Programme\Prey\base\pak003.pk4 (4111 files)
I:\Programme\Prey\base\pak002.pk4 (5337 files)
I:\Programme\Prey\base\pak001.pk4 (6270 files)
I:\Programme\Prey\base\pak000.pk4 (3318 files)
I:\Programme\Prey\base\game02.pk4 (10 files)
I:\Programme\Prey\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
2661 strings read from strings/english001.lang
Couldn't open journal files
couldn't exec editor.cfg
execing default.cfg
couldn't exec preyconfig.cfg
couldn't exec autoexec.cfg
2662 strings read from strings/german.lang
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
...initializing OpenAL
...calling LoadLibrary( 'openal32.dll' ): failed
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: Die aktuelle Kombination Grafikkarte/Treiber unterstützt nicht die erforderlichen Features.
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
:( :( :hmm:
Kann jemand Helfen? mfg. Scrj256
