Probleme beim installieren von esniper
little_skunk
Semiprofi
Hallo
ich versuche auf meinem NAS (qnap) esniper zu installieren. Ich habe die aktuelle Version runtergeladen aber ./configue funktioniert nicht. Hat jemand eine Idee was ich falsch mache? Ist mein erster Versuch ein Programm auf diesem Weg zu installieren.
Hier die Fehlermeldung:
Code:
./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /opt/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking for curl-config... curl-config
checking for curl_easy_setopt... yes
checking for curl_easy_strerror... yes
checking for cURL SSL support... yes
configure: creating ./config.status
config.status: creating Makefile
gawk: ./confq4H1pO/subs.awk:2: S["/; s/!.*/"]=am__EXEEXT_FALSE!%!_!# ""
gawk: ./confq4H1pO/subs.awk:2:                                 ^ syntax error
gawk: ./confq4H1pO/subs.awk:3: S["/; s/!.*/"]=am__EXEEXT_FALSE!%!_!# ""
gawk: ./confq4H1pO/subs.awk:3:                                     ^ syntax error
gawk: ./confq4H1pO/subs.awk:4: S["/; s/!.*/"]=am__EXEEXT_TRUE!#%!_!# "#"
gawk: ./confq4H1pO/subs.awk:4:                                ^ syntax error
gawk: ./confq4H1pO/subs.awk:4: S["/; s/!.*/"]=LTLIBOBJS!%!_!# ""
gawk: ./confq4H1pO/subs.awk:5: S["/; s/!.*/"]=LTLIBOBJS!%!_!# ""
gawk: ./confq4H1pO/subs.awk:5:                              ^ syntax error
gawk: ./confq4H1pO/subs.awk:5: S["/; s/!.*/"]=LIBOBJS!%!_!# ""
gawk: ./confq4H1pO/subs.awk:6: S["/; s/!.*/"]=LIBOBJS!%!_!# ""
gawk: ./confq4H1pO/subs.awk:6:                            ^ syntax error
gawk: ./confq4H1pO/subs.awk:6: S["/; s/!.*/"]=CURLLIBS!-L/opt/lib -lcurl -L/home/slug/optware/cs08q1armel/staging/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/home/slug/optware/cs08q1armel/staging/opt/lib -lssl -L/home/slug/optware/cs08q1armel/staging/lib -L/home/slug/optware/cs08q1armel/staging/lib%!_!# "-L/opt/lib -lcurl -L/home/slug/optware/cs08q1armel/staging/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/home/slug/optware/cs08q1armel/staging/opt/li"\
gawk: ./confq4H1pO/subs.awk:7: S["/; s/!.*/"]=CURLLIBS!-L/opt/lib -lcurl -L/home/slug/optware/cs08q1armel/staging/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/home/slug/optware/cs08q1armel/staging/opt/lib -lssl -L/home/slug/optware/cs08q1armel/staging/lib -L/home/slug/optware/cs08q1armel/staging/lib%!_!# "-L/opt/lib -lcurl -L/home/slug/optware/cs08q1armel/staging/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/home/slug/optware/cs08q1armel/staging/opt/li"\
gawk: ./confq4H1pO/subs.awk:7:        ^ syntax error
gawk: ./confq4H1pO/subs.awk:9: S["/; s/!.*/"]=CURLCFLAGS!-I/opt/include%!_!# "-I/opt/include"
gawk: ./confq4H1pO/subs.awk:9:                                             ^ syntax error
gawk: ./confq4H1pO/subs.awk:10: S["/; s/!.*/"]=CURL_CONFIG!curl-config%!_!# "curl-config"
gawk: ./confq4H1pO/subs.awk:10:                                           ^ syntax error
gawk: ./confq4H1pO/subs.awk:11: S["/; s/!.*/"]=am__fastdepCC_FALSE!#%!_!# "#"
gawk: ./confq4H1pO/subs.awk:11:                                    ^ syntax error
gawk: ./confq4H1pO/subs.awk:11: S["/; s/!.*/"]=am__fastdepCC_TRUE!%!_!# ""
gawk: ./confq4H1pO/subs.awk:12: S["/; s/!.*/"]=am__fastdepCC_TRUE!%!_!# ""
gawk: ./confq4H1pO/subs.awk:12:                                       ^ syntax error
gawk: ./confq4H1pO/subs.awk:12: S["/; s/!.*/"]=CCDEPMODE!depmode=gcc3%!_!# "depmode=gcc3"
gawk: ./confq4H1pO/subs.awk:13: S["/; s/!.*/"]=CCDEPMODE!depmode=gcc3%!_!# "depmode=gcc3"
gawk: ./confq4H1pO/subs.awk:13:                                          ^ syntax error
gawk: ./confq4H1pO/subs.awk:13: S["/; s/!.*/"]=AMDEPBACKSLASH!\%!_!# "\\"
gawk: ./confq4H1pO/subs.awk:13:                               ^ backslash not last character on line
config.status: error: could not create Makefile
Fehler gefunden. Es lag an einer falschen sed oder gawk Version. Falls jemand über google hier landet hier die Lösung:
ipkg install sed
mv /bin/sed /bin/sed-busybox
ln -s /opt/bin/gnu-sed /bin/sed
ipkg install gawk
mv /bin/awk /bin/awk-busybox
ln -s /opt/bin/awk /bin/awk
Edit: Programm läuft jetzt wie gewünscht. Wieder was dazu gelernt.
Problem mit Make
ipkg install sed
ipkg install gawk
ich habe das gleiche Problem gehabt, configure läuft jetzt. Allerdings habe mit Make auch Schwierigkeiten:
~/esniper-2-31-0 # make
source='http.c' object='http.o' libtool=no \
DEPDIR=.deps depmode=none /bin/bash ./depcomp \
gcc -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"esniper\" -DVERSION=\"2.31.0\" -I. -I/opt/include -I/opt/include -g -O2 -c http.c
http.c:30:23: curl/curl.h: No such file or directory
http.c:31:23: curl/easy.h: No such file or directory
http.c:42: error: syntax error before '*' token
http.c:42: warning: data definition has no type or storage class
http.c:43: error: syntax error before "curlrc"
http.c:43: error: `CURLE_OK' undeclared here (not in a function)
http.c:43: warning: data definition has no type or storage class
http.c:46: error: `CURL_ERROR_SIZE' undeclared here (not in a function)
http.c: In function `httpError':
http.c:66: warning: passing arg 2 of `myStrdup4' makes pointer from integer without a cast
http.c: In function `httpRequest':
http.c:160: error: `CURLOPT_FILE' undeclared (first use in this function)
http.c:160: error: (Each undeclared identifier is reported only once
http.c:160: error: for each function it appears in.)
http.c:164: error: `CURLOPT_HTTPGET' undeclared (first use in this function)
http.c:168: error: `CURLOPT_POSTFIELDS' undeclared (first use in this function)
http.c:173: error: `CURLOPT_URL' undeclared (first use in this function)
http.c: In function `initCurlStuff':
http.c:207: error: `CURL_GLOBAL_ALL' undeclared (first use in this function)
http.c:210: warning: assignment makes pointer from integer without a cast
http.c:214: error: `CURLOPT_ERRORBUFFER' undeclared (first use in this function)
http.c:219: error: `CURLOPT_VERBOSE' undeclared (first use in this function)
http.c:223: error: `CURLOPT_FOLLOWLOCATION' undeclared (first use in this function)
http.c:228: error: `CURLOPT_PROXY' undeclared (first use in this function)
http.c:232: error: `CURLOPT_WRITEFUNCTION' undeclared (first use in this function)
http.c:237: error: `CURLOPT_USERAGENT' undeclared (first use in this function)
http.c:242: error: `CURLOPT_COOKIEFILE' undeclared (first use in this function)
http.c:245: warning: assignment makes pointer from integer without a cast
http.c:246: warning: assignment makes pointer from integer without a cast
http.c:247: warning: assignment makes pointer from integer without a cast
http.c:248: warning: assignment makes pointer from integer without a cast
http.c:249: error: `CURLOPT_HTTPHEADER' undeclared (first use in this function)
http.c: At top level:
http.c:46: error: storage size of `globalErrorbuf' isn't known
make: *** [http.o] Error 1
was kann das sein? Danke für die Unterstützung im Voraus!
