Probleme mit Festplatte
Tiran0815
ich habe hier unter Debian manchmal Probleme mit einer Festplatte. Wenn ich sie im Dateimanager auswählen will friert der Dateimanager ein. Öffne ich eine neue Instanz geht er wieder, bis ich den Mountpoint wieder auswähle. Das passiert jetzt mit Dolphin und auch Thunar. Das Tool GSmartControl spuckt das hier aus. Sagt das jemanden etwas oder kann man sagen ob die Platte defekt ist? Hab erstmal alle Daten gesichert und die Partition ausgehängt.
SMART Error Log Version: 1
ATA Error Count: 8 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 8 occurred at disk power-on lifetime: 3795 hours (158 days + 3 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 00 00 00 a0
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ec 00 00 01 00 00 a0 00 00:00:00.010 IDENTIFY DEVICE
ec ff 01 01 00 00 a0 00 00:00:00.010 IDENTIFY DEVICE
00 00 00 00 00 00 00 00 00:00:00.010 NOP [Abort queued commands]
Error 7 occurred at disk power-on lifetime: 3795 hours (158 days + 3 hours)
Error 6 occurred at disk power-on lifetime: 3795 hours (158 days + 3 hours)
ec ff 01 01 00 00 a0 00 00:00:00.008 IDENTIFY DEVICE
00 00 00 00 00 00 00 00 00:00:00.008 NOP [Abort queued commands]
Error 5 occurred at disk power-on lifetime: 3795 hours (158 days + 3 hours)
Error 4 occurred at disk power-on lifetime: 3795 hours (158 days + 3 hours)
