Pterodactyl Wings Problem
tadz
ich war gerade dabei Wings einzurichten, hab dann aber gesehen dass das Herz von der Node nicht grün wird( also er sich nicht verbindet. Habe dann die Config nochmal gelöscht und von vorne begonnen, doch jetzt startet wings garnicht mehr.
Hier die Fehlermeldung:
INFO: [Apr 1 10:37:07.593] writing log files to disk path=/var/log/pterodactyl/wings.log
____
__ Pterodactyl _____/___/_______ _______ ______
\_____\ \/\/ / / / __ / ___/
\___\ / / / / /_/ /___ /
\___/\___/___/___/___/___ /______/
/_______/ 1.11.11
Copyright © 2018 - 2024 Dane Everitt & Contributors
Website: https://pterodactyl.io
Source: https://github.com/pterodactyl/wings
License: https://github.com/pterodactyl/wings/blob/develop/LICENSE
This software is made available under the terms of the MIT license.
The above copyright notice and this permission notice shall be included
in all copies or substantial portions of the Software.
DEBUG: [Apr 1 10:37:07.593] running in debug mode
INFO: [Apr 1 10:37:07.593] loading configuration from file config_file=/etc/pterodactyl/config.yml
INFO: [Apr 1 10:37:07.593] configured wings with system timezone timezone=Etc/UTC
DEBUG: [Apr 1 10:37:07.594] ensuring root data directory exists path=/var/lib/pterodactyl
DEBUG: [Apr 1 10:37:07.594] ensuring server data directory exists path=/var/lib/pterodactyl/volumes
DEBUG: [Apr 1 10:37:07.594] ensuring archive data directory exists path=/var/lib/pterodactyl/archives
DEBUG: [Apr 1 10:37:07.594] ensuring backup data directory exists path=/var/lib/pterodactyl/backups
INFO: [Apr 1 10:37:07.594] checking for pterodactyl system user username=pterodactyl
INFO: [Apr 1 10:37:07.594] configured system user successfully gid=994 uid=999 username=pterodactyl
INFO: [Apr 1 10:37:07.597] fetching list of servers from API
DEBUG: [Apr 1 10:37:07.597] making request to external HTTP endpoint endpoint=URL headers=map[Accept:[application/vnd.pterodactyl.v1+json] Authorization:[(redacted)] Content-Type:[application/json] User-Agent:[Pterodactyl Wings/v1.11.11 (id:IaZtMnNAkwYOdPhz)]] method=GET
FATAL: [Apr 1 10:37:07.816] failed to load server configurations error=manager: failed to retrieve server configurations: Error response from Panel: AccessDeniedHttpException: You are not authorized to access this resource. (HTTP/403)
Stacktrace:
github.com/pterodactyl/wings/remote.(*client).request.func1
github.com/pterodactyl/wings/remote/http.go:161
github.com/cenkalti/backoff/v4.RetryNotifyWithTimer.Operation.withEmptyData.func1
github.com/cenkalti/backoff/v4@v4.2.1/retry.go:18
github.com/cenkalti/backoff/v4.doRetryNotify[...]
github.com/cenkalti/backoff/v4@v4.2.1/retry.go:88
github.com/cenkalti/backoff/v4@v4.2.1/retry.go:61
github.com/cenkalti/backoff/v4@v4.2.1/retry.go:49
github.com/cenkalti/backoff/v4@v4.2.1/retry.go:38
github.com/pterodactyl/wings/remote/http.go:136
github.com/pterodactyl/wings/remote.(*client).Get
github.com/pterodactyl/wings/remote/http.go:81
github.com/pterodactyl/wings/remote.(*client).getServersPaged
github.com/pterodactyl/wings/remote/servers.go:201
github.com/pterodactyl/wings/remote.(*client).GetServers
github.com/pterodactyl/wings/remote/servers.go:26
github.com/pterodactyl/wings/server.(*Manager).init
github.com/pterodactyl/wings/server/manager.go:238
github.com/pterodactyl/wings/server.NewManager
github.com/pterodactyl/wings/server/manager.go:36
github.com/pterodactyl/wings/cmd.rootCmdRun
github.com/pterodactyl/wings/cmd/root.go:138
github.com/spf13/cobra.(*Command).execute
github.com/spf13/cobra@v1.8.0/command.go:987
github.com/spf13/cobra.(*Command).ExecuteC
github.com/spf13/cobra@v1.8.0/command.go:1115
github.com/spf13/cobra@v1.8.0/command.go:1039
github.com/pterodactyl/wings/cmd.Execute
github.com/pterodactyl/wings/cmd/root.go:71
main.main
github.com/pterodactyl/wings/wings.go:17
runtime.main
runtime/proc.go:267
runtime.goexit
runtime/asm_amd64.s:1650
Kann mir da jemand helfen?
Danke im vorraus
