09-07-1591
Semiprofi
Ick hab mir gedacht ich installiere aus langerweile mal wieder Q3 aber was ist? Die scheiße geht nicht !
Es kommt das hier :
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:\Quake 3 Arena\baseq3\pak1.pk3 (7 files)
C:\Quake 3 Arena\baseq3\pak0.pk3 (2964 files)
C:\Quake 3 Arena/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium VI
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:279*0
Hostname: privat
IP: *2.*68.0.*
Working directory: C:\Quake 3 Arena
----- R_Init -----
Initializing OpenGL subsystem
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
...shutting down QGL
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...unloading OpenGL DLL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
... brauche hilfe!
Es kommt das hier :
execing default.cfg
Winsock Initialized
Hostname: privat
IP: *2.*68.0.*
----- R_Init -----
...initializing QGL
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...calling CDS: ok
...35 PFDs found
...35 PFDs found
RE_Shutdown( 1 )
... brauche hilfe!
