Volition hat, wie versprochen, endlich einen Patch für den Shooterhit Red Faction veröffentlicht, den ihr euch ruhig einmal ziehen könnt.
Er behebt massig Bugs, hier die komplette
Liste:
-Made changes to require fewer hard drive accesses during gameplay.
-Fixed data-mismatch problem when joining a multiplayer server that gave the "Data does not match" error message.
-Fixed instances where a multiplayer server would crash when kicking a player.
-Fixed railgun trajectory visual to no longer deflect off some walls.
-Fixed crash from clicking on scroll bar in multiplayer map list.
-Fixed misplaced dedicated server/password icons on Servers screen when using 1280 resolution.
-Fixed selection problem when changing Filter on Servers screen.
-Fixed server list to properly identify servers running mods
-Fixed console closing problem. Only need to hit "~" once now.
-Fixed crash instances caused by hitting both "Shift" keys simultaneously.
-L14S3 endgame screen text now displays properly in 800x600.
-Railgun will properly fire through multiple targets.
-Removed delay in picking up dropped weapons in multiplayer.
-First-person arms on "Scientist Parker" and "Ultor Scientist" now match models in multiplayer.
-Zooming in with scoped weapons now displays scope if first person weapons are turned off.
-Disabled "Shift-Esc" to quit out of game.
-Dedicated server now skips over any missing maps found in map lists.
-Disabled save games during the bomb defuse screen.
-RED levels now work when you install the game to a directory path with spaces in it.
-Fixed crash with the RED running out of VRAM when desktop is at very high resolutions.
-Changed RED to favor the updated CHM help file, if it exists.
-Removed unused flags from RED's Light Properties dialog.
-RED can now import V3D files as mesh brushes. Requires V3D exporter for 3ds Max found in the RFToolkit.
Red Faction Patch 1.1 (dt.)
Red Faction Patch 1.1 (engl.)
Liste:
