Release Notes for iCUE 5.11.95
CORSAIR Marcus
Corsair Support
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.11.95 Issues Resolved
Software Enhancements
  • iCUE will no longer crash when switching presets in Murals
  • Improved tooltips for better consistency and placement in iCUE
  • When Lighting Layers are toggled, the last layer in the list will no longer be auto-selected
  • Naming a Murals effect with a long name will no longer cause the Go To Murals button to disappear
  • Resolved an issue that causes the device image to increase in size briefly when trying to downsize
  • Hovering over shortened text on a sensor in Dashboard will now properly show the full text as a tooltip
  • Resolved an issue that caused graphs to still appear for sensor widgets in Dashboard even after hiding them
  • Improved the responsiveness of the Color Wheel
HID Product Enhancements
  • Resolved an issue with French language that affected Macro – Copy Event and Macro – Delete Event
  • Copying “Switching Profile” as an assignment will now be possible even without a key being assigned
  • Cancelling the firmware update on Void RGB ELITE Wireless will no longer cause it to disappear from the device list
  • Resolved various lighting effects issues with NIGHTSABRE, DARKSTAR, and K70 PRO Wireless
  • Resolved an issue with NEXUS battery status widgets that prevented certain devices from reporting their battery levels
  • A background image will now properly be displayed when a screen on NEXUS is imported
DIY Product Enhancements
  • Resolved an issue that affected Time Warp lighting after a device’s firmware update is completed
  • Resolved an issue that affected Fan Curves with Fixed % and Fixed RPM when used with Fahrenheit units
  • Resolved an issue that caused profile 4 in Performance Manager for DDR5 to not appear unless iCUE is restarted
  • VOYAGER battery widget will now properly report its battery level
  • Rotary Stack and Spiral Rainbow will now play properly on the Hydro X XG7 RGB
  • Resolved an issue that caused the iCUE LINK HUB to display an improper text string when the language is changed
  • Resolved an issue with the 1000D in Murals that prevented some options from appearing during configuration
  • LT100 tower adjustment now works properly when changing the device tower arrangement
