ROG Delta kein 7.1
FloGo
Huhu all,
I bought the ROG Delta based on many good reviews and I am satisfied so far.
However, despite the virtual surround sound being activated, I only have sound on the FL and FR channels.
Also in the 7.1 volume control, I can only set the FL and FR channels.
No matter what I try (reinstall drivers and software), I just can't get it set.
I have added 2 screenshots that show that the other channels cannot be set and do not work either.
In the test it shows surround at the bottom, but as I said, it only plays on the FL and FR channels.
How do I get this to work?!
MfG FloGo
Push..
Push.. :-/
the asus support isnt as active as it should be
would try it in the rog forum
