![000521331.jpg](http://img5.pcpop.com/ProductImages/500x375/0/521/000521331.jpg)
es gibt demnächst einige neue Monitore von Samsung. Darunter ein quasi "226BW in 24 Zoll" (Klavierlackoptik) mit der Modellbezeichnung 2493HM. Und da wollte ich mal fragen, ob es schon Reviews oder ähnliches gibt...
Ich für meinen Teil finde leider nichts dergleichen und die Infos die ich habe sind recht dürftig, da noch viele Fragen offen sind (Welches Panel? etc.).
Geizhals.at
http://geizhals.at/deutschland/a306942.html
Die "einzigen" Informationen kommen von der Herstellerseite...
http://www.samsung.com/us/consumer/...=monitors&subtype=lcd&model_cd=LS24KIEEFV/XAA
http://www.samsung.com/us/consumer/...ubtype=lcd&model_cd=LS24KIEEFV/XAA&fullspec=F
http://downloadcenter.samsung.com/content/EM/200711/20071128184939312/EN/MAIN.HTM
24'' LCD monitor
The 2493HM has everything that you need. With a Height Adjustable Stand (HAS), built-in-speakers, HDMI technology, full 1080p HD, 10,000:1 Contrast Ratio and fast response time, you will be able to power through a work day and watch a movie or play games with all of the extra free time that you will have. Not to mention, the eye catching bezel design will fit perfectly in public view or in the comfort of your home office. The 2493HM is Microsoft Vista Certified and works hard while looking good. With the 2493HM it’s not hard to imagine.
HDMI and built-in speakers all-in-one
With HDMI and built-in speakers, the 2493HM is a comprehensive entertainment solution.
5 ms fast response time
Fast pixel response means fast action with virtually no blurring of ghosting.
certified for Windows Vista operating system
Premium certification is reserved only for products proven to take full advantage of everything the Microsoft Windows Vista operating system offers.
10000:1 dynamic contrast ratio
Most often talked about with LCD monitors is the measure of the difference of brightness levels between the brightest white and the darkest black. With a dynamic contrast ratio of DC 10000:1, you are assured crisp easy-to-view images.
4-way adjustable stand – height, swivel, tilt, pivot
In many modern corporations it’s necessary to offer solutions that meet ergonomic standards. The 2493HM with HAS (Height Adjustable Stand) will keep your business in regulations and operating at maximum efficiency.
key specifications
* Screen Size : 24"
* Resolution : 1920 x 1200
* Brightness : 400 cd/m²
* Contrast Ratio : DC10000:1 (1000:1)
Screen Size 24"
Resolution 1920 x 1200
Brightness 400 cd/m²
Contrast Ratio DC10000:1 (1000:1)
Response time 5 ms
Viewing Angle (Horizontal / Vertical) 160º / 160º
Video Signal D-sub, DVI, HDMI
Sync. Signal separate, composite
Connector D-sub, DVI, HDMI
Power 100W
Stand By Power (DPMS) 1.5W
Plug & Play Yes
Speakers 4W (2W x 2Ch.)
Accessories User's manual, USB cable, Power Adaptor, DVI cable etc.
Shipment Dimension 25.71'' x 20.47'' x 11.77''
Product Weight 18.74 lb
Shipment Weight 24.03 lb
Function of stand. Tilt is basic and Height adjusting, Pivot & Swivel is optional one tilt, swivel, pivot, height adjustment
Mit freundlichen Grüßen
Botox
