Seagate Barracuda 7200.9 ST3160212AS defekt ?
jayhay
Hi, habe hier nen PC wo Windows nichtmehr startet (Windows Loadscreen kommt nichtmal - Bildschirm bleibt schwarz)
Über eine Linux Live CD kann ich auf die Systempartition nicht zugreifen und angezeigt wird 141 GB von 141 GB frei.
Habe mit smartctl Fehler ausgelesen (siehe Errorlog unten).
Kann mir jemand sagen ob man die Festplatte lieber austauschen sollte bevor ich wieder versuche Windows zu installieren ?
smartctl 6.0 2012-10-10 r3643 [i686-linux-3.5.6-pmagic] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, smartmontools
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.9
Device Model: ST3160212AS
Serial Number: 9LS386C6
Firmware Version: 3.AAE
User Capacity: 160,041,885,696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Sun Jan 14 03:56:39 2007 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: ( 430) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 54) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 115 091 006 Pre-fail Always - 90830820
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 097 097 020 Old_age Always - 3429
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 23
7 Seek_Error_Rate 0x000f 083 060 030 Pre-fail Always - 229277895
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3198
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 097 097 020 Old_age Always - 3444
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 5937
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 067 056 045 Old_age Always - 33 (0 1 34 33 0)
194 Temperature_Celsius 0x0022 033 044 000 Old_age Always - 33 (0 12 0 0 0)
195 Hardware_ECC_Recovered 0x001a 075 047 000 Old_age Always - 20599671
197 Current_Pending_Sector 0x0012 044 044 000 Old_age Always - 1146
198 Offline_Uncorrectable 0x0010 044 044 000 Old_age Offline - 1146
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0
202 Data_Address_Mark_Errs 0x0032 100 253 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 990 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 990 occurred at disk power-on lifetime: 3196 hours (133 days + 4 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 1f fa 00 e0 Error: UNC at LBA = 0x0000fa1f = 64031
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 00 00 fa 00 e0 00 01:30:50.466 READ DMA EXT
25 00 80 20 fa 00 e0 00 01:30:50.451 READ DMA EXT
25 00 00 00 fa 00 e0 00 01:31:00.861 READ DMA EXT
25 00 08 08 fa 00 e0 00 01:31:00.846 READ DMA EXT
25 00 00 00 fa 00 e0 00 01:30:57.782 READ DMA EXT
Error 989 occurred at disk power-on lifetime: 3196 hours (133 days + 4 hours)
25 00 08 08 fa 00 e0 00 01:30:50.451 READ DMA EXT
25 00 00 00 fa 00 e0 00 01:30:48.680 READ DMA EXT
25 00 80 88 f9 00 e0 00 01:30:48.664 READ DMA EXT
Error 988 occurred at disk power-on lifetime: 3196 hours (133 days + 4 hours)
40 51 00 1c fa 00 e0 Error: UNC at LBA = 0x0000fa1c = 64028
25 00 80 88 f9 00 e0 00 01:30:50.451 READ DMA EXT
25 00 00 00 f9 00 e0 00 01:30:48.664 READ DMA EXT
25 00 00 00 f8 00 e0 00 01:30:46.911 READ DMA EXT
Error 987 occurred at disk power-on lifetime: 3196 hours (133 days + 4 hours)
25 00 00 00 f9 00 e0 00 01:30:50.451 READ DMA EXT
25 00 00 00 f8 00 e0 00 01:30:48.680 READ DMA EXT
25 00 00 00 f7 00 e0 00 01:30:48.664 READ DMA EXT
25 00 80 88 f6 00 e0 00 01:30:46.911 READ DMA EXT
Error 986 occurred at disk power-on lifetime: 3196 hours (133 days + 4 hours)
40 51 00 74 f6 00 e0 Error: UNC at LBA = 0x0000f674 = 63092
25 00 00 00 f6 00 e0 00 01:30:50.466 READ DMA EXT
25 00 08 78 f6 00 e0 00 01:30:50.451 READ DMA EXT
25 00 00 00 f6 00 e0 00 01:30:48.680 READ DMA EXT
25 00 18 40 f6 00 e0 00 01:30:48.664 READ DMA EXT
25 00 00 00 f6 00 e0 00 01:30:46.911 READ DMA EXT
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed: read failure 90% 3197 16841247
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
23 defekte Sektoren wurden schon durch Reservesektoren ersetzt und 1146 weitere Sektoren konnten nicht korrekt gelesen werden, die sollen beim Überschreiben geprüft und ggf. ebenfalls ersetzt werden.
Bei der Anzahl würde ich die Platte ersetzen. Du kannst sie aber mal komplett überschrieben, z.B. mit dd if=/dev/zero of=/dev/sdx bs=64k und dann noch mal sehen wie die Werte dann aussehen.
