[Guide] Select an excellent converter to remove DRM protection
kanhuadeng
Have you heard of DRM? Its full name is Digital Rights Management, which aims to protect copyright.
If you want to visit the files with DRM, you need to know the password or pay for it. However, you wish to save time and money. Then how can you solve the trouble?
What you need is DRM Media Converter, which can help you remove the DRM protection.
Best DRM Converter introduces two excellent DRM converters for users. And you can have a scan to make a choice.
The first one is DRM Media Converter .
Specially designed to remove DRM protection of video and audio and even HD files, DRM Media Converter can broke all popular videos like MP4, MPG, MPEG, 3GP, RM, RMVB, DAT, MOV, FLV, and audios such as MP3, WAV, M4A, WMA, OGG, AAC, APE. The DRM Media Converter also plays the role of video converter, with which you can convert all popular HD and SD video files, and it also allows you extract audio from video. It is compatible with any digital players such as iPod, Creative Zen, Zune, iPhone, PSP, Archos, etc. Owning the highest technology, this software can help you convert files four times faster than others.
Furthermore, its optimized DRM crack engine allows you to adjust conversion settings with your own style.
The other one is DRM Music Converter
As a DRM remover and converter, this DRM Music Converter aims to remove music DRM protection from music and Windows Media Player, as well as convert DRM music to popular audio formats like WMA, M4A, M4B, AAC, AC3, WAV and MP3, etc. Plus, it is also possible to use this tool to convert unprotected music to other formats. It is mainly direct to music fans and can customize music profile like sample rate, bit rate and audio channel. With a friendly interface, it is very easy to master this software.
Having viewed the introduction above, you can see that if you want to remove DRM about video file, you can use DRM Media Converter; if you want to break audio DRM, DRM Music Converter is a good helper. Both are excellent software. Just download them for free trail.
