Shell Script Fehler ??
NiclasM
Dortmund
Hi
Angeblich ist in Zeile 92 u 94 ein fehler :
./scrip.sh: line 92: unexpected EOF while looking for matching `"'
./scrip.sh: line 94: syntax error: unexpected end of file
ich seh da nix ?!?
Code:
#!/bin/bash
echo "####################################"
echo ""
echo "  Select"
echo "  [1] Install Apache + PHP + MySQL"
echo "  [2] Install NXserver and User Remote"
echo "  [3] Install GNOME "
echo "  [4] Show System Informations"
echo "  [5] Usefull Programm's"
echo "  [6] Add APT-Mirror ?"
echo ""
read select
apt-get update
if [ "$select" = "1" ]
        then
        apt-get update
        apt-get -y install apache2 php5 mysql-server
fi
if [ "$select" = "2" ]
        then
                echo "Model : i386 or AMD64 ?"
                read $model
                if [ "$model" = "i365" ]
                then
                cd /tmp
                wget http://64.34.161.181/download/3.4.0/Linux/nxclient_3.4.0-5_i386.deb
                wget http://64.34.161.181/download/3.4.0/Linux/nxnode_3.4.0-6_i386.deb
                wget http://64.34.161.181/download/3.4.0/Linux/FE/nxserver_3.4.0-8_i386.deb
                dpkg -i nxclient_3.4.0-5_i386.deb
                apt-get -y -f install
                dpkg -i nxnode_3.4.0-6_i386.deb
                dpkg -i nxserver_3.4.0-8_i386.deb
                fi
                        then
                        cd /tmp
                        wget http://64.34.161.181/download/3.4.0/Linux/nxclient_3.4.0-5_x86_64.deb
                        wget http://64.34.161.181/download/3.4.0/Linux/nxnode_3.4.0-6_x86_64.deb
                        wget http://64.34.161.181/download/3.4.0/Linux/FE/nxserver_3.4.0-8_x86_64.deb
                        dpkg -i nxclient_3.4.0-5_x86_64.deb
                        apt-get -f install
                        dpkg -i nxnode_3.4.0-6_x86_64.deb
                        dpkg -i nxserver_3.4.0-8_x86_64.deb
                        fi
                apt-get install xauth
                echo "What name should the NX User have ?"
                read $user
                adduser $user
                /usr/NX/bin/nxserver --keygen
                cp /usr/NX/share/keys/default.id_dsa.key /home/$user/nx-key.key
                echo "The SSH Key for Login is under /home/$user/nx-key.key
fi
if [ "$select" = "3" ]
        then
        apt-get install xserver-xorg gnome-core
fi
if [ "$select" = "4" ]
        then
        cat /proc/cpuinfo >> /tmp/cpuinfo | grep "model name" /tmp/cpuinfo
        rm /tmp/cpuinfo
fi
if [ "$select" = "5" ]
        then
        apt-get install vlc kvm qemu virt-manager icedove iceweasel network-manager-gnome gimp openoffice.org pidgin blender filezilla sun-java6-jre wine
fi
if [ "$select" = "6" ]
        then
        mv /etc/apt/sources.list /etc/apt/sources.list.bk
        touch /etc/apt/sources.list
        echo "What IP have you APT-Mirror Server ?"
        read $server
        echo "deb http://$server/Mirror/ftp.de.debian.org/debian/ lenny main" >> /etc/apt/sources.list
        echo "deb-src http://$server/Mirror/ftp.de.debian.org/debian/ lenny main" >> /etc/apt/sources.list
        echo "deb http://$server/Mirror/security.debian.org/ lenny/updates main" >> /etc/apt/sources.list
        echo "deb-src http://$server/Mirror/security.debian.org/ lenny/updates main" >> /etc/apt/sources.list
       echo "deb http://$server/Mirror/volatile.debian.org/debian-volatile lenny/volatile main" >> /etc/apt/sources.list
       echo "deb-src http://$server/Mirror/volatile.debian.org/debian-volatile lenny/volatile main" >> /etc/apt/sources.list
fi
Jemand eine Idee ?
In der folgenden Zeile fehlt am ende ein "
