Smart-Werte von meinen Laufwerken....
Dani77
Habe von meinen Laufwerken (sda bis sdg) unter Linux die Smart-Werte abgerufen.
Code:
smartctl -A /dev/sda
smartctl 6.4 2015-06-04 r4109 [x86_64-linux-4.4.6-gentoo] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   000    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   000    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       20123
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       139
170 Grown_Failing_Block_Ct  0x0033   100   100   000    Pre-fail  Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
173 Wear_Leveling_Count     0x0033   100   100   000    Pre-fail  Always       -       33
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       1
181 Non4k_Aligned_Access    0x0022   100   100   000    Old_age   Always       -       0 0 0
183 SATA_Iface_Downshift    0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   000    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 Factory_Bad_Block_Ct    0x000e   100   100   000    Old_age   Always       -       523
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   100   100   000    Old_age   Always       -       0
202 Percent_Lifetime_Used   0x0018   100   100   000    Old_age   Offline      -       0
206 Write_Error_Rate        0x000e   100   100   000    Old_age   Always       -       0
smartctl -A /dev/sdb
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate     0x000f   111   098   006    Pre-fail  Always       -       33172749
  3 Spin_Up_Time            0x0003   100   100   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       61
  5 Reallocated_Sector_Ct   0x0033   003   003   036    Pre-fail  Always   FAILING_NOW 3975
  7 Seek_Error_Rate         0x000f   078   060   030    Pre-fail  Always       -       68357323
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       17604
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       54
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   098   098   000    Old_age   Always       -       2
190 Airflow_Temperature_Cel 0x0022   058   052   045    Old_age   Always       -       42 (Min/Max 26/47)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       20
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       61
194 Temperature_Celsius     0x0022   042   048   000    Old_age   Always       -       42 (0 18 0 0 0)
195 Hardware_ECC_Recovered  0x001a   045   012   000    Old_age   Always       -       33172749
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       18069 (195 102 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2897391158
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1792816752
smartctl -A /dev/sdc
  1 Raw_Read_Error_Rate     0x000f   116   099   006    Pre-fail  Always       -       112564240
  3 Spin_Up_Time            0x0003   093   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       62
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   069   060   030    Pre-fail  Always       -       7864480
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       19593
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       56
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   063   051   045    Old_age   Always       -       37 (Min/Max 26/42)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       18
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       62
194 Temperature_Celsius     0x0022   037   049   000    Old_age   Always       -       37 (0 18 0 0 0)
smartctl -A /dev/sdd
  1 Raw_Read_Error_Rate     0x000f   118   099   006    Pre-fail  Always       -       193753040
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       65
  7 Seek_Error_Rate         0x000f   064   060   030    Pre-fail  Always       -       3130485
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       19592
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       59
190 Airflow_Temperature_Cel 0x0022   065   050   045    Old_age   Always       -       35 (Min/Max 26/41)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       21
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       65
194 Temperature_Celsius     0x0022   035   050   000    Old_age   Always       -       35 (0 17 0 0 0)
smartctl -A /dev/sde
  1 Raw_Read_Error_Rate     0x000f   117   099   006    Pre-fail  Always       -       132321664
  7 Seek_Error_Rate         0x000f   063   060   030    Pre-fail  Always       -       2612673
190 Airflow_Temperature_Cel 0x0022   065   051   045    Old_age   Always       -       35 (Min/Max 26/42)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       17
194 Temperature_Celsius     0x0022   035   049   000    Old_age   Always       -       35 (0 18 0 0 0)
smartctl -A /dev/sdf
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   131   131   054    Pre-fail  Offline      -       116
  3 Spin_Up_Time            0x0007   100   100   024    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       1
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       55
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       180
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       180
194 Temperature_Celsius     0x0002   136   136   000    Old_age   Always       -       44 (Min/Max 24/47)
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
smartctl -A /dev/sdg
  1 Raw_Read_Error_Rate     0x000f   114   100   006    Pre-fail  Always       -       64302416
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       34
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   062   060   030    Pre-fail  Always       -       1589073
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       536
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       34
190 Airflow_Temperature_Cel 0x0022   062   056   045    Old_age   Always       -       38 (Min/Max 20/42)
194 Temperature_Celsius     0x0022   038   044   000    Old_age   Always       -       38 (0 18 0 0 0)
195 Hardware_ECC_Recovered  0x001a   053   041   000    Old_age   Always       -       64302416
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       457 (25 86 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       906514371
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2543008768
smartctl -A /dev/sdh
  1 Raw_Read_Error_Rate     0x000f   118   100   006    Pre-fail  Always       -       200827311
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       35
  7 Seek_Error_Rate         0x000f   062   060   030    Pre-fail  Always       -       1608195
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       400
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       35
190 Airflow_Temperature_Cel 0x0022   057   055   045    Old_age   Always       -       43 (Min/Max 21/43)
194 Temperature_Celsius     0x0022   043   045   000    Old_age   Always       -       43 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   048   036   000    Old_age   Always       -       200827311
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       322 (71 109 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1053422761
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       3813067116
sda ist ein SSD Laufwerk, die Anderen sind alle drehende Festplatten.
sdb ist mein Temp und Download Laufwerk auf dem viel geschrieben wird.
sdf ist neu im System, ist es normal das die Werte von "Power-Off_Retract_Count" und "Load_Cycle_Count" so schnell steigen?
sdf ist eine neue WD Red 8 TB. sdc, sdd und sdd sind Seagate Nas Laufwerke.
Bei Welchem Laufwerk sind die Werte sehr kritisch?
Ich lese und sehe die Werte, verstehe Sie auch teilweise, aber bin mir nicht sicher was mir das jetzt alles sagen soll?!?
/dev/sdb ist dürfte sehr bald ausfallen: "5 Reallocated_Sector_Ct 0x0033 003 003 036 Pre-fail Always FAILING_NOW 3975"
Vielleicht war der eine Schlag den der G-Sensor im Betrieb registiert hat, schon zu viel für sie:
"191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 1"
Bzgl. dem "Power-Off_Retract_Count" verhalten sich die 8TB WD HDDs wie die HGST HDDs und damit ist es normal, dass der synchron zu dem "Load_Cycle_Count" verläuft, bei denen in meinen 8TB MyBooks ist es auch so.
