TViX M5000U, echter HD Media Player mit einem Sigma EM 8621 Chip
Kubrick
Hallo an alle!
Hier erst mal ein paar Informationen des Herstellers:
TViX HD can playback high definition video (up to 1920x1080i) and still images. Pre-recorded HDTV programs from a digital TV set-top box or personal digital video contents taken by a HDV™ camcorder can be played back with TViX HD on a high definition display. The TViX HD features a DVI connector and component, which matches the high resolution of HD level video contents.
Multimedia Player
TViX HD is a standalone, multimedia hard disk player which can play digital videos, digital music, digital still images and DVD files to a TV display and home entertainment system. Now you can enjoy digital contents in the comfort of your own living room without having to burn discs or having to play it back on a DVD or CD player anymore.
DVD Jukebox
TViX HD can playback DVD movies with the full functionality of DVD navigation. You can create your own virtual DVD library by storing your private collection of DVDs in .ISO or .IFO format and watch them exactly as if they were running from the original DVDs (all original features included: Menu, Chapter, Audio Stream, Subtitle, Fast Forward, Rewind, Slow, Pause, Step Forward, Repeat, Search, etc.).
Network Connectivity
The TViX HD can be networked with a PC system using its built-in LAN port. You are able to navigate to a file in a PC on TViX’s network and play the file from its original destination without having to first copy it onto the TViX HD.
USB2.0 Host
With two USB2.0 host ports, you can now attach additional external USB hard drives to further extend the storage capacity or transfer files from another USB device such as a thumb drive. You can also playback files from a digital camera, USB flash driver, USB flash card reader, or a MP3 player.
Main Chipset Sigma Design EM8621
VFD Display 7 Alpha-Numeric Character
5 Digit Numeric Display
Video Format :.wmv, .avi, .mpg, .vob, .mp4, .asf, .tp, .trp
Codec : MPEG 1 / 2 / 4, DivX, XVID
Resolution Up to 1920 x 1080i
Audio MP3, WMA, AAC, Ogg, PCM
Multimedia Digital Sound, DTS Pass Through and Down Mixing
Photo BMP, JPG
Connectivity USB2.0 Host 2 Ports
USB2.0 Target 1 Port
LAN(10/100Mbps)
Multi I/O Jack (Optional Breakout Box)
AV In / Out Video
DVI, Component, S-Video, Composite,
Audio
Digital : Coaxial, Optical / Analog: Stereo
File System Formats NTFS, FAT32
Subtitle Text Subtitle : smi,sub,srt,aqt,utf,lrc / Image Subtitle : sub (with idx)
Compatible HDD IDE HDD ( SATA HDDs are not supported)
ODD Support Through USB 2.0 Host*
Language English, French, German, Spanish, Italian, Portuguese, Swedish, Norwegian, Danish, Japanese, Korean
FAN 40mm Brushless FAN
FAN Control Temperature Sensing
Varialble Speed
Main Memory Main Memory
Flash ROM 8 Mbyte
Internal Power 90~240V Free Voltage
Shape Cylindrical
Dimension 131mm(Diameter) 185mm(Height)
Weight 1,200g (without HDD) 1,800g (with HDD)
Hier ein link zu einer review des mpc-club:
http://www.mpcclub.com/banner_log.php?id=5008
Ich finde das hört sich alles ziemlich fett an. Sehr gut finde ich auch die Möglichkeit über den Multi I/O Jack einen DVB/T Empfänger anzuschließen (Optional Breakout Box, soll demnächst von Dvico released werden) und so aus der Mediabox auch noch einen Festplattenrekorder zu machen. Auch die die Anschlussmöglichkeit von zwei zusätzlichen ext. Festplatten finde ich herausragend.
Wenn jemand Erfahrungen mit dem M5000U hat, postet sie bitte.
Schöne Grüße,
Kubrick
