Unplugged 3090 Ti. Plugged Rtx 4090. Black screen in post and red light in mobo
swrt45
Profi
Hi. I have 12900K stock
32 GB 2x16 GB DDR4 3600mhz
Palit Gamerock Pro OC rtx 4090
1300W Seasonic Platinum Prime
Windows 11 2H22. Updated new nvidia drivers.
I unplugged 3090 ti. And plugged Rtx 4090. And on first boot was black screen ( no signal ) on monitor, and motherboard was lightning in red. I waited 2 minutes then i heard windows 11 boot ring sound. And display appear. And its fine now. Why that happehed on first time? Just black screen no signal and red ligt in motherboard ( like before windows ). Now its fine. Should i worry?
Tested 3dmark and its fine.
>Should I worry
Nope
Der erste Start nach einer Hardware Änderung kann länger dauern.
The first start after some change can take a lot of time.
It Sounds like the same Problem what i see in this Video from Jay.
