Was ist DRAM idle Timer
Voyager
Bei meinen 2x512 MB MDT zeigt CPU-z an: 16 clocks
und bei 2x1 GB Samsung UCCC sagt CPU-z: 256 clocks
Was ist das überhaupt für ein Wert,kann man dem im Bios ändern und wenn ja bringt das leistungstechnisch etwas ?
Thx
geh mal hier schauen: http://www.dfi-street.com/forum/showpost.php?p=203179&postcount=4
Idle Cycle Limit
Settings = Auto, 0-256 in varied increments.
From the DFI BIOS: “This BIOS setting specifies the number of memclocks before forcibly closing (pre-charging) an open page.” It appears that this setting is the maximum number of tries allowed for a page of memory to be read before arbitration kicks in and forces pre-charge once again for that page.
Slight Influence on Bandwidth/Larger Influence on Stability.
Suggested Settings for DFI: The Auto setting defaults to 256 clocks which seems to be overkill. If your RAM is lower grade----then I would stay with Auto. If your RAM is a step up, I would try 16-32 clocks. I had good luck with 16 clocks on BH-5. (Lower = Faster)
