Hardwarekenner
Legende
wie ist eure meinung zu den Aktuellen o.B. Sound lösungen?
wenn ich sehe das die meisten MBs schon 7.1 mit HD Audio draufhaben, und diese auch EAX unterstützen, lohnt es mom für Gamer noch viel Geld für eine Creative oder änliche Soundkarte auszugeben, zumal ja so wie es scheint EAX mit Vista sterben wird?
das mal zum Realtek ALC888 HD der auf vielen MBs verbaut wird.
Features
* Hardware Features High-performance DACs with 97dB SNR (A-Weighting), ADCs with 90dB SNR (A- Weighting)
* Meets performance requirements for Microsoft WLP 3.0 Premium desktop and mobile PCs
* Ten DAC channels support 16/20/24-bit PCM format for 7.1 sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel output
* Two stereo ADCs support 16/20/24-bit PCM format, one for stereo microphone, one for legacy mixer recording
* All DACs supports 44.1k/48k/96k/192kHz sample rate
* All ADCs support 44.1k/48k/96k sample rate
* 16/20/24-bit S/PDIF-OUT supports 44.1k/48k/96k/192kHz sample rate
* 16/20/24-bit S/PDIF-IN supports 44.1k/48k/96k/192kHz sample rate
* Up to four channels of microphone array input are supported for AEC/BF application
* High-quality analog differential CD input
* Supports external PCBEEP input and built-in digital BEEP generator
* Software selectable 2.5V/3.75V VREFOUT
* Two jack detection pins each designed to detect up to 4 jacks
* Supports legacy analog mixer architecture
* Wide range (–80dB ~ +42dB) volume control with 1.5dB resolution of analog to analog mixer gain
* Software selectable boost gain (+10/+20/+30dB) for analog microphone input
* All analog jacks are stereo input and output re-tasking for analog plug & play
* Built-in headphone amplifiers for each re-tasking jack
* Two GPIOs (General Purpose Input and Output) for customized applications
* Supports anti-pop mode when analog power AVDD is on and digital power is off
* Supports digital microphone interface for improved voice quality 48-pin LQFP ‘Green’ package
Software Features
* Meets Microsoft WHQL/WLP 3.0 audio requirements
* WaveRT-based audio function driver for Windows Vista
* EAX™ 1.0 & 2.0 compatible
* Direct Sound 3D™ compatible
* A3D™ compatible
* I3DL2 compatible
* HRTF 3D Positional Audio
* Emulation of 26 sound environments to enhance gaming experience
* 10-Band Software Equalizer
* Voice Cancellation and Key Shifting in Karaoke mode
* Realtek Media Player
* Enhanced Configuration Panel to improve user experience
* Microphone Acoustic Echo Cancellation (AEC), Noise Suppression (NS), and Beam Forming (BF) technology for voice application
* ALC888DD-GR features Dolby® Digital Live and DTS® CONNECT™ software (Optional)
* ALC888H-GR features Dolby® Home Theater(software feature)
Features
Software Features
* A3D™ compatible
* I3DL2 compatible
