Memtest version 4.22 (64-bit)
Copyright (C) 2004 Charles Cazabon
Copyright (C) 2004-2008 Tony Scaminaci (Macintosh port)
Licensed under the GNU General Public License version 2 only
Mac OS X 10.7.2 (11C74) running in multiuser mode
Memory Page Size: 4096
System has 2 Intel core(s) with SSE
Requested memory: 6357MB (6666616832 bytes)
Available memory: 6357MB (6666616832 bytes)
Allocated memory: 6357MB (6666616832 bytes) at local address 0x0000000101000000
Attempting memory lock... locked successfully
Partitioning memory into 2 comparison buffers...
Buffer A: 3178MB (3333308416 bytes) starts at local address 0x0000000101000000
Buffer B: 3178MB (3333308416 bytes) starts at local address 0x00000001c7ae4000
Running 1 test sequence... (CTRL-C to quit)
Test sequence 1 of 1:
Running tests on full 6357MB region...
Stuck Address : setting 1 of 16
FAILURE! Data mismatch at local address 0x0000000130d2c000
Actual Data: 0x0000000130d20000
Linear PRN : setting 1 of 16
FAILURE! Data mismatch at local address 0x000000013150e000
Expected Data: 0x36bc6c39d2099313, Actual Data: 0x36bc6c39d2097913
Running comparison tests using 3178MB buffers...
Random Value : \
FAILURE! Data mismatch at local BUFA address 0x000000013150e000, BUFB address 0x00000001f7ff2000
BUFA Data: 0x5ffb10d26cff4a26, BUFB Data: 0x5ffb10d26cfff626
Compare XOR :
FAILURE! Data mismatch at local BUFA address 0x0000000130d2c000, BUFB address 0x00000001f7810000
BUFA Data: 0x011338ad8054ec6d, BUFB Data: 0x011338ad8054806d
Compare SUB :
BUFA Data: 0x9aa492590c5d7ac3, BUFB Data: 0x9aa492590c5ca8c3
Compare MUL :
BUFA Data: 0xf6068d255abe9ef4, BUFB Data: 0x377e937132086ef4
Compare DIV :
FAILURE! Data mismatch at local BUFA address 0x0000000130d2c060, BUFB address 0x00000001f7810060
BUFA Data: 0x0000000000000001, BUFB Data: 0x0000000000000000
Compare OR :
FAILURE! Data mismatch at local BUFA address 0x0000000131967000, BUFB address 0x00000001f844b000
BUFA Data: 0x6befd36abfbe000d, BUFB Data: 0x6befd36abfbeda0d
Compare AND :
FAILURE! Data mismatch at local BUFA address 0x00000001325fe080, BUFB address 0x00000001f90e2080
BUFA Data: 0x22af924a3b3eda0d, BUFB Data: 0x22af924a3b3e1a0d
Sequential Increment:
BUFA Data: 0x38de19b6f56daeb4, BUFB Data: 0x38de19b6f56d48b4
Solid Bits : setting 1 of 64
FAILURE! Data mismatch at local BUFA address 0x000000013212b000, BUFB address 0x00000001f8c0f000
BUFA Data: 0xffffffffffff72ff, BUFB Data: 0xffffffffffffffff
Block Sequential : setting 1 of 256
FAILURE! Data mismatch at local BUFA address 0x00000001325fe000, BUFB address 0x00000001f90e2000
BUFA Data: 0x000000000000ff00, BUFB Data: 0x0000000000000000
Checkerboard : setting 1 of 64
BUFA Data: 0x5555555555550055, BUFB Data: 0x5555555555555555
Bit Spread : setting 1 of 128
FAILURE! Data mismatch at local BUFA address 0x000000013212b080, BUFB address 0x00000001f8c0f080
BUFA Data: 0x0000000000005505, BUFB Data: 0x0000000000000005
Bit Flip : setting 1 of 512
BUFA Data: 0xffffffffffff00fe, BUFB Data: 0xfffffffffffffffe
Walking Ones : setting 1 of 128
FAILURE! Data mismatch at local BUFA address 0x00000001315f0008, BUFB address 0x00000001f80d4008
Walking Zeroes : setting 1 of 128
FAILURE! Data mismatch at local BUFA address 0x000000013150e280, BUFB address 0x00000001f7ff2280
BUFA Data: 0x000000000000ff01, BUFB Data: 0x0000000000000001
*** Address Test Failed *** One or more DIMM address lines are non-functional.
Execution time: 92 seconds.
