!!Welt neuheit !!!GeForce FX5700 Ultra Grafikkarte mit LCD-Display!!!
Chucky
Banned
[OST]BERLIN Hardware Senior Profi
PixelView GeForce FX5700
PixelView GeForce FX5700 Ultra
What's PixelView PDF™ technology?
PixelView PDF™ is "The super Cooling System with Blue Icy Crystal Displaye",which embraces the following excellent benefits
Blue Icy Crystal Displayer
- Show your GPU temperature and fan speed
- Allow you to monitor the GPU temperature and fan speed instantly.
(Real-time RPM & Temperature detective response technology)
Noise Reduction Technology (around 25dB)
As the GPU becomes more and more powerful,"how to prevent noisy cooling fan"is the biggest and first priority of PROLINK R&D team. Have you ever experienced the annoying cooling fan while playing game on your PC? No worry, PixleView PDF™ technology embraces the Noise Reduction Technology, which can be around 25dB and allows you to play game silently!
Anti-Overheated Cooling System (More than 100% heat dissipation)
- Designed to prevent air being blocked by other PCI card
- High quality aluminum cover with quick heat dissipation
- Ventilation holes for quick cold and hot airflow
Audio Alarm Warning (Real-time RPM & Temperature detective response Technology)
When GPU fan speed is below 1000RPM & Temperature is higher than 70, the audio alarm will be on automatically. With this function, it assures you that your GPU is running under a normal condition.
45° View Angle LCD Design
- World's NO.1 45 degree view angle design
- No matter which angle you place your PC; you can monitor your GPU temperature and fan speed immediately
Durable Life-cycle
With all the above advantages, we are proud of announcing that PixelView GeForce FX5700/5700 Ultra series provide you the capability of "Dominating Your Games" !!!
@Quelle
prolink.com.tw
Die Karte würd ein Renner werden in Deutschland ein traum für jeden Case modder ;-) damit ist PixelView mal wieder was gelungen
der Peis wird sehr intersant sein denn Pixelview Karten waren noch nie Teuer ;)
jetzt müßte die karte nur noch schnell genug sein um z.b. den windows desktop darstellen zu können - ein traum wäre minesweeper ohne ruckler :p
du sagst es ja schon. sie waren noch nie teuer ;)
@gilletti
lol :d
das ist dann wieder so ne 5700pro@5900 preiskarte
(erinnere mich noch gut an die goldensample 4200, welche vom preis anner ti 4400 lagen :fresse: )
na klasse, können di9e so was nicht mit ner richtigen 5950 oder so machen? Ati wäre mir auch lieber, naja was solls, schick aber sinnlos...
Jeder NF7 user wird das teil HASSEN !
Ich hab die Leadtek 5800 und dieis etwa leich lan und hat auch so nen Kasten
1. Das dingen is wohl lauter als der nVidia orinal staubsauger !
2. man bekommt den RAM nicht mehr raus und der Kühlkörper liegt fest am RAM-Feststellhebel an
3. Die Grafikkarte ausbaun is wegen den AGP Feststellheben nur mit extremster fumelei zu schffen und ohne sonstige PCI karten eingebaut
4. Der Secondary IDE is versperrt
... dat is mir aber egal denn die Leadtek Kühlung wird durch nen CoolJag Vollkopfer CPU Kühler und Revoltec RAM Kühlers ersetzt :banana:
