Western Digital 1TB Defekt?
  • Ersteller Gelöschtes Mitglied 42549
  • Erstellt am
G
Guest
ich habe hier 2 1TB Festplatten am Linuxrechner. Folgende Ausgaben liefern die Platten:
Platte 1 (ätere der beiden, stammt aus einer 2010er Mybook USB 2.0)
Platte 2, Seagate 1TB, ca. von 2014
Code:
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  575) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 111) minutes.
Conveyance self-test routine
recommended polling time:        (   2) minutes.
SCT capabilities:              (0x3085) SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -       211928048
  3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       995
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   076   060   030    Pre-fail  Always       -       43360198
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       2326
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       992
183 Runtime_Bad_Block       0x0032   040   040   000    Old_age   Always       -       60
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1 1 3
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   053   045    Old_age   Always       -       28 (Min/Max 21/28)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       215
193 Load_Cycle_Count        0x0032   091   091   000    Old_age   Always       -       18737
194 Temperature_Celsius     0x0022   028   047   000    Old_age   Always       -       28 (0 17 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       4
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1962h+21m+30.170s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       73555108066427
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       249081641247606
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%       640         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Beide Platten zeigen im Status schon mehrere Pre-Fail an.
Kann doch nicht sein, dass die Platten Reihenweise kaputt gehen?
Pre Fail ist nur die Beschreinung des Attributes und die erste Platte ist absolut in Ordnung, die zweiten im Prinzp ebenfalls, wenn man davon ausgeht das es eine Seagate und keine WD ist, denn die Werte sind typisch für Seagte Platten. Leider hast Du ja nicht die komplett Ausgabe von smartctl -a gepostet, sonst hätte man es oben sehen müssen.
Dort stört mich einzig "183 Runtime_Bad_Block ... 60", wobei ich nicht sicher bin ob es der korrekte Name für das Attribut ist und defekte Sektoren werden ja keine angezeigt, weder schwebenden noch wieder zugewiesene. Auch gibt es weder Lese- noch Suchfehler, wenn wir davon ausgehen, dass es eine Seagate und keine WD ist. Dann hat die zweite auch noch 4 Ultra-DMA CRC Fehler (Attribut 199, letzte Spalte), wenn es mehr werden gibt es ein Problem mit dem SATA Datenkabel.
Danke Holt,
mir ist da ein kleiner Fehler unterlaufen, die 2. Platte ist in der Tat eine Seagate und keine WD.
Platte 2 hängt in einer Icybox an USB 3.0
