henryevans
Profi
There are 5 main types of vacuum cleaners: stick, canister, handheld, robot, and upright. Each type offers specific features for certain uses and purposes. One of the most popular types is the upright vacuum. Searching for a powerful upright vacuum? If you have no idea about what to purchase, Shark Navigator Lift-Away Deluxe NV360 is the one that you can take into consideration. This device features all that you can expect from a vacuum cleaner. The following will provide general information about this model, specified in the product review.
Shark NV360 Review
First things first, Shark NV360 is a blue bagless upright vacuum cleaner by Shark. The unit includes 3 filters – 2 pre-motor (located just below the dust canister) and 1 post-motor (located behind the grill on the lower front of the vacuum), which can be rinsed in water and reused. There are four main tools attached with a Shark Navigator lift-away NV360: pet power brush, dusting brush, crevice tool, and under appliance wand. You can use the Upright mode for upright vacuuming – floors and carpets, and the Lift-away mode – for cleaning hard-to-reach places. Have a look at its key features, specification, and pros & cons below:
Related Article: Shark NV360: All You Need to Know About This Powerful Vacuum
1. Key features:
Shark navigator lift-away deluxe nv360 offers HEPA filter and an Anti-Allergen Complete Seal Technology. This allows a vacuum to contain disease-causing particles inside the unit. Not all, the filter is detachable, so it can be washed and well-cleaned for the next use.
The Shark Navigator NV360 includes a Pet Power brush, which is applicable for picking up long pet hair. If you are living with those who have allergies with feathers and hairs, this model is right for your house.
2. Blue Shark vacuum NV360 - Specifications
Shark Navigator Lift-Away Deluxe NV360 works by using advanced cyclonic technology. This means, the dust from the air sucked into the vacuum can be totally separated.
The dust cup plays a part in holding all the dust collected during the vacuuming process. Keep in mind that the dust cup should be emptied after every use.
The steer attached inside the vacuum moves around the surface. Thus, it is ideal for vacuuming furniture, as well as other hard-to-reach edges.
The brush works through a motor system. This makes the cleaning task more efficient and faster.
4. Shark navigator lift away deluxe - Pros and cons
Pros:
Customer ratings by features
- Easy to assemble: 4.7/5
- Suction power: 4.6/5
- Cleaning up hair: 4.4/5
- Versatility: 4.⅘
- Durability: 4.3/5
- For stairs: 4.2/5
- Top 3 pros mentioned: suction, cleaning, lightweight
- Top 3 cons mentioned: cord, hose, easy to remove
Final words:
If you have already referred to many Shark navigator lift away deluxe reviews on websites, you might see that the Navigator Lift-Away Deluxe NV360 is usually on top of the “should-have” list regarding vacuum cleaners. There is no appliance that is 100% perfect. However, Shark NV360 can surely be one of the most popular options as the pros outweigh the cons, and the advantages offered are more-than-enough from what you can expect from an upright bagless vacuum cleaner.
Do you currently own Shark NV360 reviews? What is your experience using this device? Feel free to leave your comment in the section below.
Shark NV360 Review
1. Key features:
- Lift-away feature
- Filtration system
- Swivel steering
- Dust cup capacity
- Pet power brush
- Upright and bagless vacuum
- Total weight: 12.5 pounds
- The canister alone weight: 7.5 pounds
- Dust cup capacity: 1.2 dry quarts
- Item dimensions: 14.96 x 11.40 x 45.50 inches
- Lift-away feature
- Swivel steering for maneuvering around furniture
- Extended reach by using the wand to easily clean overhead
- Upholstery tool
- Power cord length: 25 feet
- Crevice tool: 5.5 inches and cleaning path: 11 inches
- Motor: 120V, 10Amps, 1200W. Generate strong suction power
- Brushroll shutoff
- Specific uses for product: Dual action
- Offers a HEPA filter
- Anti-Allergen Complete Seal Technology
- No batteries required
Pros:
- Multi-purpose: Shark navigator lift-away deluxe nv360 upright vacuum can be used to clean hard floors, furniture, and carpets, as well as pick-up pet hair with ease.
- Fast in action
- Easy to empty and clean the dust bag
- Easy to store
- Lightweight
- The suction power can be adjusted.
- Low noise when in operation
- Navigator Lift-Away Deluxe NV360 comes with the brush roll with on or off switch button. You can switch “on” for cleaning carpeted areas, and switch “off” for vacuuming hard floors.
- Safe for those who are allergy sufferers. A HEPA filter and Anti-Allergen Complete Seal Technology ensures to remove 99.9% of disease-causing particles. These traps allergens inside the body part of the machine and thus, friendly with all users.
- It features a portable detachable canister
- Affordable price at approximately $140
- Warranty: 5 years from the original purchase date
- Power cord length (25 feet), which causes some certain limitations and reduces its room coverage
- The dust cup is small, compared to the other models of upright vacuum cleaner
- Do not have headlights
- Have a shorter hose than the other models of upright vacuum cleaners
- Amazon
- Versatility: 4.⅘
- Durability: 4.3/5
- For stairs: 4.2/5
- Walmart
- Bestbuy
Final words:
