wie hz zahl ändern in cs ?
nodynude
wie bekomm ich die hertz zahl in cs geändert?
ich dachte immer das wird vom desktop übernommen ?
cs grafik settings:
modi: opengl
aufl.: 1920x1440
farbe: 32bit
gibts da irgend nen consolen befehl für?
greetz alex
ps: das steht bei mir iner config
Code:
unbindall
bind "TAB" "+showscores"
bind "ENTER" "+attack"
bind "ESCAPE" "cancelselect"
bind "SPACE" "+jump"
bind "'" "+moveup"
bind "+" "sizeup"
bind "," "res1"
bind "-" "sizedown"
bind "." "res2"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "sizeup"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "b" "buy"
bind "c" "radio3"
bind "d" "+moveright"
bind "e" "+use"
bind "f" "impulse 100"
bind "g" "drop"
bind "h" "+commandmenu"
bind "i" "showbriefing"
bind "j" "cheer"
bind "k" "+voicerecord"
bind "m" "chooseteam"
bind "n" "nightvision"
bind "o" "buyequip"
bind "q" "lastinv"
bind "r" "+rl"
bind "s" "+back"
bind "t" "impulse 201"
bind "u" "messagemode2"
bind "w" "+forward"
bind "x" "radio2"
bind "y" "messagemode"
bind "z" "radio1"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "CTRL" "+duck"
bind "SHIFT" "+speed"
bind "F1" "autobuy"
bind "F2" "rebuy"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F10" "quit prompt"
bind "INS" "+klook"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "centerview"
bind "KP_HOME" "name1"
bind "KP_UPARROW" "name2"
bind "KP_PGUP" ".deagle"
bind "KP_LEFTARROW" ".scout"
bind "KP_5" ".awp"
bind "KP_RIGHTARROW" ".mp5"
bind "KP_END" ".deagle"
bind "KP_DOWNARROW" ".mp5"
bind "KP_PGDN" ".teamrifle1"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "MOUSE2" "+attack2"
bind "PAUSE" "pause"
_cl_autowepswitch "1"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "1.000000"
bottomcolor "6"
brightness "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "30"
cl_corpsestay "600.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "auto"
cl_crosshair_translucent "1"
cl_dlmax "128"
cl_download_ingame "1"
cl_dynamiccrosshair "1"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "0"
cl_radartype "0"
cl_righthand "1"
cl_shadows "1"
cl_timeout "35"
cl_updaterate "60"
cl_vsmoothing "0.05"
cl_weather "1"
con_color "255 180 30"
console "1.000000"
crosshair "1.000000"
fastsprites "0"
fps_max "70"
fps_modem "0"
gamma "3"
gl_dither "1"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "4"
hud_capturemouse "1"
hud_centerid "1"
hud_draw "1"
hud_fastswitch "0"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0.000000"
lookstrafe "0.000000"
m_filter "0"
m_forward "1"
m_pitch "0.022000"
m_side "0.8"
m_yaw "0.022"
model "gordon"
MP3FadeTime "2.0"
MP3Volume "0.380000"
mp_decals "300.000000"
name "nur.ne.aushilfe"
net_graph "3"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
s_a3d "0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1.0"
s_verbwet "0.25"
sensitivity "7"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "4"
spec_pip "0"
suitvolume "0.250000"
sv_aim "0"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120.000000"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.750000"
volume "0.800000"
setinfo "_vgui_menus" "0"
setinfo "_ah" "1"
+mlook
+jlook
exec userconfig.cfg
aso? hmm...hab aber trotzdem son flimmern als wenn ich ne zuniedrige hertz zahl hätte
Google mal nach "60 hertz" Bug, und such nach Programmen die diesen lösen sollen ;)
google mal nach reforce
damit kannste einstellen unter welcher auflösung du wieviel hz haben möchstest, damit kannste z.b. auch cs1.6 in 85hz und höher zocken :bigok:
foxxx
ich hab ja kein prob mit den fps
des reforce tool ding da is ja schon alles eingestellt ?
und irgendwie gibts die gleichen einstellungen auch im forceware
-freq 100
in die launch options bei steam für counter-strike... das war's - ohne irgendwelche tools :d
fps_max "70" -> fps_max "100"
Das wäre das allererste, was ich grad mal machen würde ;)
sexy gleich ma test0rn xD
äh ja moment das bezieht sich doch auf die fps oder?
ja schon probiert ich hab kein fps problem sondern ein flimmern im menü und im spiel ;)
also erstens fps_max "101" ;)
2tens virtualsync auschalten!
-freq 100 dürfte dir nichts bringen, da es sich um einen TFT handelt! da gehn die HZ nicht über 75, und bei der auflösung glaub ich noch weniger, müsstest du nachschauen!
ich habe mit dem 940bf einfach FPS_MAX "101" und vsync off, ansonsten kannst du auch mal vsync ON probieren wenn du es zurzeit off hast
Wird in dem Options-menü deines Monitors nicht die Aktuelle Hertz-Zahl angezeigt?
vsync ist aus
fps_max 100
un wie was tft ?
ja aufl. 1920x1440@75hz
ja sir für was ist das den, die hertz ?
mein moni macht nur 75 bei der aufkösung ;)
ne halt ! meine graka macht nur 75 ^^ öhm...sehr verwirrent
wo steht das?
@nodynude: hallo? schreibst du ma bitte -freq 100 in die launchoptions o0
schau dir die auflösung an ;)
-freg 100 soll im spiel 100HZ "ermöglichen", denke das problem liegt aber in den grafiktreibereinstellung
€: 75 HZ flimmern nicht! vielleicht bei nem normalen CRT, aber ein TFT flimmert selbst bei 60HZ nicht!
die 75HZ macht nicht deine graka, denke die ist zu mehr imstande ;) es leigt einfach daran das es keine TFTs gibt die nativ über 75 HZ ermöglichen! es gibt zwar modelle mit 100hz, dort wird aber umgerechnet usw. was das ergebnis nur noch schlimmerm macht!
warum redest du dauernd von TFT? er hat ne röhre!
des -freq 100 hat scheinbar geholfen nur is auch mein cs flimmerfrei :)
sollte dein monitor jetzt wirklich mit 100hz laufen, aber nur 75 unterstützen, entfern es lieber wieder, das können CRTs nämlich garnicht leiden. jeder crt, den ich bis jetzt gesehen habe, zeigt zwar bei zu hoher freq "out of range" an, aber n paar leute haben mir auch schon erzählt, dass es wohl monitore gibt, die das nicht machen...
aha also -freq 100 auf 75 ?
kompliziertes thema ^^
sry für die verspätung ^^
läuft prima !
danke!!
