phlebiac
Semiprofi
H.A.R.L.I.E. / G.O.D. / HAL 9000 / COLOSSUS
Well, every little project needs a name ... and if only to give the topic here a proper title ... so ... here we go
H.A.R.L.I.E / G.O.D.
Based on the Book When HARLIE Was One by David Gerrold
Central to the story is an Artificial Intelligence named H.A.R.L.I.E., also referred to by the proper name "HARLIE" - an acronym for
Human Analog Replication, Lethetic Intelligence Engine (originally Human Analog Robot Life Input Equivalents).
G.O.D. is an acronym for Graphic [/B]O[/B]mniscient Device and is something bigger than HARLIE himself, and to be created by HARLIE.
HAL 9000
HAL 9000 is a fictional character in Arthur C. Clarke's Space Odyssey series. The primary antagonist of 2001: A Space Odyssey, HAL (Heuristically programmed ALgorithmic computer) is a sentient computer (or artificial intelligence) that controls the systems of the Discovery One spacecraft and interacts with the ship's astronaut crew. Being a computer, HAL has no distinct physical form, though is visually represented as a red television camera eye located on equipment panels throughout the ship.
COLOSSUS
HAL 9000
COLOSSUS
Main Hardware & Operating System
- Microsoft Windows 7 Ultimate (x64) Build 7601 Service Pack 1 - English NON-UEFI
- Case: CaseLabs Magnum M8 (black matte, double wide case) ... P ... M ... Store
Specifications:
- Size: 15"W x 19.06"H x 20.06"D (381mm x 484mm x 510mm)
- PCI Slots: 8
- Form Factor: mATX, ATX, SSI-CEB MB tray dimensions: 12.0" x 10.75” (305mm x 273mm)
- Max Radiator Size: 120.3
- Radiator Clearance Above the MB Tray: 100mm
- Radiator Clearance Below the MB Tray: 52mm
- Cooling Tower Clearance: 180mm
- Flex-Bays (5.25” Bays): 10
- HDD Capacity: 12 (24 using Flex-Bays)
- Weight: 19 lbs.
Features and standard equipment:- All aluminum construction - .090" (2.3mm) chassis .063"(1.6mm) doors/covers
- Slide out MB tray.
- One HDD cage assembly (4 drive capacity): either standard or Flex-Bay mount. Note that the flex-bay mount deletes one of the 3U bay covers.
- Dual PSU mounts (Support bracket available: MAC-123)
- Integrated radiator/fan mounts
- Two single bay filler plates, one double bay filler plate and two triple bay cover plates.
- Filler plates for the top and bottom radiator openings, 40mm fan openings on MB tray (if selected), PCI slots, and one PSU.
- Four sets of standard device mounts for 5.25” devices (MAC-125)
- Lamptron anti-vandal style switches (power 22mm & reset 16mm) with fully sleeved wiring harnesses: blue ring for power and red dot for HDD activity. They are standard switches that can be easily swapped out for custom color combinations.
- Four rubber feet with screws (casters are available: MAC-107).
- Misc. hardware: Thumbscrews, MB standoffs, Tie-wraps, etc.
- Available in black matte, white matte and gray primer (gray primer is not a cosmetic finish)
- USV : Eaton 3S 700 USV ... P ... PF ... USVs ... M
- PSU : Enermax Platimax EPM600AWT ... P ... PF ... M
- Mainboard : Asus Maximus V Formula / ThunderFX (Socket 1155) @ BIOS 1802 ... P-ROG / P / M-ROG / M / S / ThunderFX
- CPU : Intel Core i7-3770K (Socket 1155) @ defaults ... Batch# 3229A802 Costa Rica ... P ... M ... S ... T ... PF
- GPU : EVGA GeForce GTX 670 FTW 2GB ... P ... M ... S
- RAM : CORSAIR Vengeance 32GB Dual/Quad Channel DDR3 Memory Kit (CMZ32GX3M4X1866C10) ( 4x8GB ) @ 1333MHz DS 9-9-9-24 1.5V ... P / M
- HDD Power Controller : Lian Li BZ-H06B Black - 6x HDD Power Switch ... P ... M
- Addon Card 1 : Asus U3S6 2xUSB 3.0 2xSATA 6G ... P
- SSD1 : Samsung 830 Series SATA 6Gb/s 256GB MZ-7PC256B/WW @ Scythe Himuro SCHM-1000 @ Intel #1 ... P ... M ... S
- SSD2 : Samsung 830 Series SATA 6Gb/s 256GB MZ-7PC256B/WW @ Scythe Himuro SCHM-1000 @ Intel #2 ... P ... M ... S
- HDD1 : Western Digital Caviar Black 2TB @ Lian Li BZ-H06B @ Scythe Himuro SCH-1000 @ Intel #3 ... P / M / O
- HDD2 : Western Digital Caviar Black 2TB @ Lian Li BZ-H06B @ Scythe Himuro SCH-1000 @ Intel #4 ... P / M / O
- HDD3 : Western Digital Caviar Green 3TB @ Lian Li BZ-H06B @ Intel #5 ... P / M / O
- HDD4 : Western Digital Caviar Green 3TB @ Lian Li BZ-H06B @ Intel #6 ... P / M / O
- HDD5 : Western Digital Caviar Green 2TB @ Lian Li BZ-H06B @ Intel #7 ... P / M / O
- HDD6 : Western Digital Caviar Green 2TB @ Lian Li BZ-H06B @ Intel #8 ... P / M / O
- HDD7 : Western Digital Caviar Green 2TB @ Asus U3S6 ... P / M / O
- CD/DVD : Samsung SE-208AB/TSRS (external, red) ... P
- HDD Case 3.5 : Scythe Himuro SCH-1000 ... P ... M
- HDD Case 2.5 : Scythe Himuro Mini 2,5" SCHM-1000 ... P ... M
- Monitor 1 : 22" WS HP w2207h (GM757AA) @ 1680x1050 ... P / P2 / M
- Monitor 2 : 22" WS HP w2207h (GM757AA) @ 1680x1050 ... P / P2 / M
- Mouse 1 : Logitech G500 ... P / M / S
- Mouse 2 : Logitech G500 ... P / M / S
- Mouse 3 : Logitech G5 ... P / M
- Mousepad : Mionix Sargas 360 (Micro fibre surface) ... P ... M
- Keyboard : Corsair Vengeance K70 Cherry MX Red ... P / M / Amazon / K70 S / MECHA S
- Keyboard (old) : Logitech Internet Navigator Keyboard ... P / M
- Call & Surf Comfort VDSL/Universal (VDSL 50) @ Deutsche Telekom AG
- Speedport W921V rented @ Deutsche Telekom AG
Watercooling Hardware
- Controlling : Aquacomputer Aquaero 5 XT ... AQC-S / AQC-P / S / M
- Controlling : Aquacomputer Austauschfront im neuen Design ... AT-S
- Controlling : Aquacomputer Frontblende schwarz ... AT-S
- Controlling : Aquacomputer Aquaero 5 LT ... P / AT-S
- Controlling : Aquacomputer mounting plate for poweradjust 2 USB, Aluminium black anodized ... AT-S ... ? mounting plate for aquaero 5 lt ?
- PUMP : Swiftech MCP35X ... P / HF-S
- DECOUPLING1 : Aquacomputer Shoggy Sandwich Bausatz 2.0 Black ... AT-S
- DECOUPLING2 : Phobya Universal Pumpen Befestigungssockel ... AT-S
- FILTER : Aquacomputer Filter mit Edelstahlgewebe, Absperrhähnen und Einbaublende G1/4 ... AT-S
- CPU Cooler : Koolance CPU-380I Water Block (Intel Processor) ... P/ M / AT-S
- GPU Cooler : XSPC Razor GTX680 (New Style) ... P ... M (should fit on the 670 FTW @ 680 Reference Design) / S 680
- VRM Cooler: Fusion Thermo (onboard Maximus V Formula)
- PCH Cooler : EK Water Blocks EK-FB KIT ASUS M5F - Acetal + Nickel (PCH Only) ... P
- Aquaero Cooler: Aquacomputer Wasserkühler für Aquaero 5, G1/4 ... P
- Radiator : Phobya Xtreme SUPERNOVA 1260 ... at-s
- Radiator Stand : Phobya Radiator Stand - black - Bench Edition: Supernova ... at-s
- AGB1 : Monsoon Series Two Dual 5.25" Reservoir - Matte Black ... AT-S
- TUBE : 5 m Tygon R3603 Schlauch 15,9/9,5mm (3/8"ID) Clear AT-S
- COOLING LIQUID : 3 x Innovatek Protect Konzentrat 500ml ... AT-S ... (=6L)
- DFM : Aquacomputer Durchflusssensor mps flow 200, G1/4 ... AT-S / AQC-S
- THS1 : Thermosensor Black Matt ... z.B. für AGB ... sieht ähnlich aus wie dieser hier, nur etwas kürzerer Stift (P)
- THS2 : Phobya Thermosensor In-Line 2x G1/4 IG - black matt ... AT-S
- THS3 : Phobya Thermosensor In-Line 2x G1/4 IG - black matt ... AT-S
- FITTINGS : Monsoon 16/10 Matte Black ... AT-S
| P = Product Website | M = Manufacturer Website | S = HWLUXX Sammelthread | T = HWLUXX Testthread | PF = Product Family Website | AT = aquatuning.de |
Other Things to buy / do
- Keyboard : Corsair K70
- Monitor: 3rd 22" HP w2207h
- MDPC Sleeve (lots of it in different colors)
- Backplate : EVGA 670 FTW Backplate 670 Version Backplate 670 FTW soon available again
- Phobya Vandalismus / Klingeltaster 19mm (body) 22mm (face) red Ring ... AT-S
- CaseLabs Magnum M8 Accessories ... lots of it like additional hdd cages, ...
- Change Lian Li SATA-Powerswitch Blue LED's to red LED's ... if possible
- Change Aquaero 5 XT Front (see Watercooling Hardware)
- GPU Backplate Cooling: simply thermal pad between GPU back and backplate
- CPU Backplate Cooling: simply thermal pad between CPU/Mainboard back and CPU/backplate + ram-coolers on backplate
- Paint slot cover plates
- Make aquaero display red colored
Links of Interest ...
- http://www.hardwareluxx.de/community/f137/wakue-quatsch-thread-ungesplittet-802786.html
- http://www.hardwareluxx.de/communit...hluesse-wasserzusaetze-thread-6-a-792044.html
- http://www.hardwareluxx.de/community/f137/der-agb-crash-sammelthread-857775.html
- http://www.hardwareluxx.de/community/f136/11-waermeleitpasten-im-vergleich-831414.html
- http://www.hardwareluxx.de/communit...ammelthread-bitte-startpost-lesen-880908.html
- http://www.hardwareluxx.de/communit...taturen-und-andere-sonderwuensche-757147.html
- http://www.hardwareluxx.de/community/f81/how-sleeve-803756.html
- http://www.hardwareluxx.de/communit...oenes-rot-wie-ohne-nebenwirkungen-916620.html
- Bundymania Test/Reviews
- SSD Write Endurance (Samsung 830 Series 256GB DIED @ 6.22PiB+) SSD Write Endurance 25nm Vs 34nm and last testing result posted (see post #5393 and #5400)
Suche ...
- [url=http://www.hardwareluxx.de/community/f108/suche-ausgediente-defekte-120mm-140mm-200mm-220mm-luefter-gummirahmen-920036.html]Suche ausgediente / defekte Lüfter ab 120mm + Gummirahmen
