Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Das P5E und das Maximus sind im Prinzip fast die selben Boards, deshalb geht das auch.
Hier Steht wo sie sich unterscheiden:
Zitat:
However, you shouldn’t think that less expensive Asus P5E has the same functional features as Maximus Formula. The developers have definitely changed the design in order to lower its production cost. You can actually see the major differences right away: P5E has no second Gigabit network controller and has simpler cooling system for the chipset and processor voltage regulator. Moreover, there are a few smaller differences, too. For example, our board features only four fan connectors, there are no Power On and Reset button on the PCB, no connectors for external thermal sensors and no LED indicators for the voltages on the major mainboard knots (aka Voltiminder LED technology). There are fewer accessories bundled with the board: for example, P5E comes with no LCD poster indicator and no CD disk with additional software (Maximus Formula comes with S.T.A.L.K.E.R. game, 3DMark06 Advanced Edition benchmark and Kaspersky antivirus).
