Xtreamer Ultra2 Deluxe/Barebone, USB 3.0 Bluray Combo
omnium
Banned
Xtreamer schrieb:
What is Xtreamer Ultra2:
The Xtreamer Ultra2 is a portable HTPC equipped with 6 USB, eSATA, 4 Gb DDR3 RAM, HDMI, an integral IR remote control and powered by the Nvidia GT520M Chip that allows vivid and crisp playback of FULL HD multimedia files. The Xtreamer Ultra2 devices incorporate state-of-the-art technology, commonly used in high-end computing and consumer electronic solutions. The highly refined manufacturing process, timeless engineering and careful quality-control have once again resulted in a product that works out of the box yet embraces the highest long-term aesthetic and commercial value. We hope that anyone who wants a very capable yet portable PC will find the Xtreamer Ultra2 to be a rewarding experience and a worthy investment both as FULL HD streamer as well as a Windows 7 or Linux based computing system.
Xtreamer schrieb:
USB 3.0 External Blu-ray combo
slimmest portable BD Writer with USB bus power support in the world It’s also a perfect solution for those users who are looking for a compact -sized, trendy and portable BD Writer. You can enjoy your High-Definition Blu-ray movies anywhere anytime. SmoothLinkTM Buffer Under-run Prevention technology prevents buffer under-run errors and secures stability when writing.
Finde ich persönlich zu teuer, kann man sich leicht günstig selber bauen.
Jepp die Teile sind Blödsinn in meinen Augen, wie alle diese Mediaboxen die um 200€ liegen. Man kann besseres für 200€ selber bauen.
ich finds net schlecht, gute Alternative zum Asrock ION HT.
Nicht jeder will oder kann selber bauen (und dürfte auch schwer werden in diesem Formfaktor). Und die Leistung reicht für den Zweck völlig, mehr braucht man nicht.
