hat jemand schon getestet ob der zalman auf die 6600gt agp version der sparkle geht???
der support konnte mir das nicht hunderprozentig bestätigen. ich möchte halt den lauten lüfter der sparkle aussttauschen! möchte aber auch mich versichern dass das auch klappt
hier die mail vom support:
Hello!!
Thank you for your interest in Zalman products.
As you see below, the VGA chipset of the 6600GT AGP is located on an unusual spot, upper side, compared with the 6600GT PCle. Therefore, its installation might be structurally unstable because most of the pressure can be added on the edge of the card, not the center.
Further more, a heatsink for the HSI is inevitable to cool. If you don't have it on the card, the VF700 shouldn't be used.
For these reasons, we can't dare to say that the VF700 series is 100% compatible with the 6600GT AGP even if this model has many good points. So, it is up to the space in the case and up to you. Sorry for not giving you a clear answer but this is the situation we have here.
If you have any further enquiry, please feel free to contact us any time.
Best regards,
Support / Zalman
DANKE
Hello!!
Best regards,
Support / Zalman
DANKE
