OCZ mit neuen PC3700 Modulen
Heute hat [url=http://www.ocztechnology.com/]OCZ[/url] seine neuen PC3700 (DDR466) Enhanced Bandwidth DDR Module vorgestellt. Die Module haben Timings von CL3-3-2-8 und laufen bei 2.8 Volt. Die Dual-Channel Kits werden auf einem ASUS P4C800 Deluxe getestet und erst dann zusammen verpackt. Natürlich sind diese High-End Module wieder mit einem aus Kupfer gefertigten Heat-Sink versehen. Bisher werden 2x 256 MB DIMM (OCZ466512EBDCPE-K) und 2x 512 MB DIMM (OCZ4661024EBDCPE-K) angeboten.[center][img]http://www.hardwareluxx.de/andreas/News/platinumsingle_pc3700eb.jpg[/img][/center]
[center][img]http://www.hardwareluxx.de/andreas/News/platinumsingle_pc3700eb_k.jpg[/img][/center]
Sunnyvale, CA. April 20, 2004 - OCZ Technology Group, a worldwide leader in innovative, ultra high-performance memory solutions for PC enthusiasts and gamers, today announced the release of PC-3700 Enhanced Bandwidth DDR memory in single module and dual channel kit configurations.
Each PC-3700 module and Dual Channel kit features an integrated copper platinum-layer heatspreader to aid in heat dissipation and are rated for CL3-3-2-8(read: CAS-tRCD-tRP-TRAS) latencies at 2.8 volts.
In order to ensure that OCZ PC-3700 EB Platinum DDR modules and Dual Channel kits perform to OCZ's exacting performance and quality standards, all modules and Dual Channel kits are hand-tested by OCZ technicians using the Asus P4C800 Deluxe mainboard before they are shipped. OCZ PC-3700 EB Platinum DDR modules are covered by OCZ's no-hassle lifetime warranty and technical support service.
" With PC-3700 EB DDR, OCZ has addressed the latency issues that have been associated with high speed memory for so long " said Dr. Michael Schuette, director of technology development with OCZ Technology Group. "OCZ has spent a considerable amount of time developing memory that is able to run high speeds at 3-3-2 timings and we are very pleased with the end results."
Under many conditions, OCZ PC-3700 EB Platinum DDR modules are capable of maintaining 3-2-2 latency settings to allow enthusiasts even more aggressive settings if they wish to tweak their systems
OCZ PC-3700 EB Platinum DDR modules and Dual Channel kits will begin shipping immediately. For price and availability please check with your preferred OCZ retailer. For more information o­n OCZ PC-3700 EB DDR modules and Dual Channel kits, please visit the OCZ product page here.
Quellen und weitere Links
    KOMMENTARE ()
