DDR Voltage Booster von OCZ
Mit dem OCZ DDR Booster Voltage Diagnostic Device erlaubt es [url=http://www.ocztechnology.com]OCZ[/url] dem Anwender, die VDIMM-Spannung auf maximal 3.9 Volt anzuheben.
OCZ DDR Booster Voltage Diagnostic Device with Patented PowerClean Technology™ allows users to supply cleaner power to their memory modules, resulting in more stable memory. Additionally, users are able to view memory module voltage with the digital LEDs o­n the DDR Booster, allowing simple and inexpensive troubleshooting of the memory modules. Each OCZ DDR Booster allows VDIMM adjustments up to 3.9V* and is compatible with most DDR1 motherboards.[center][img]http://www.hardwareluxx.de/andreas/News/ddrbooster.jpg[/img][/center]
Quellen und weitere Links
    KOMMENTARE ()
