OCZ stellt PC2-5400 DDR2 Enhanced Bandwidth Platinum vor
[url=http://www.ocztechnology.com]OCZ[/url] hat gestern seinen PC2-5400 Enhanced Bandwidth Speicher aus der Platinum Edition Serie vorgestellt. Die Module laufen mit 677 MHz und Timings von 4-2-2-8 bei 2.1 Volt. Es sind sowohl 512 MB (2x 256 MB) als auch 1 GB (2x 512 MB) Dual-Channel Kits verfügbar.
OCZ Platinum PC2-5400 marks a milestone in the world of high speed DDR2. These high performance modules offer lower latencies than standard DDR2-667; with speeds up to 667MHz at 4-2-2 timings, PC2-5400 EB delivers incredible performance and stability. OCZ DDR2-667 Platinum is built with the proprietary Enhanced Bandwidth Technology feature to provide intelligent bandwidth management by offering the lowest possible page access times while reducing the strain on the DRAM I/O logic by allowing relaxed CAS latencies that are hidden behind burst outputs of data. The result is unsurpassed effective data bandwidth to allow maximizing system performance without compromising stability.[center][img]http://www.hardwareluxx.de/andreas/News/OCZ_PC25400EBDC.jpg[/img][/center]
