[url=http://www.supertalent.com]Super Talent[/url] hat heute zwei neue DDR1 Dual-Channel Kits vorgestellt. Beide Kits bestehen aus jeweils zwei 1 GB Modulen. Das X40PB2GC3 Kit besteht aus zwei 1 GB PC4000 CAS-3 Modulen, die bei einer Frequenz von 500 MHz mit Standard-Timings laufen. Das X32PB2GC2 Kit setzt sich aus zwei 1 GB PC3200 CAS-2 Modulen zusammen. Beide Kits sind ab sofort im Handel erhältlich.These products were developed specifically for gamers and enthusiasts who need top notch performance with no compromises in reliability. Both kits have been tested extensively in Super Talent's engineering labs on multiple enthusiast motherboards to ensure compatibility and reliability. Every module built is subjected to a full battery of production testing at its rated specifications before it gets the Super Talent label.Both these new memory kits are clad in thermally bonded aluminum heat spreaders to deliver optimum thermal performance. Keeping critical components cool not only enhances performance, it also extends the life of the components. Super Talent backs all their DRAM modules with a lifetime warranty.
According to Super Talent Marketing Manager, David Crume, "Super Talent has established a solid reputation for building quality desktop memory. With these products, we've leveraged our engineering and manufacturing strengths to make a competitive entry into the performance memory market."
