ATIs Stellungename zu den Cheat Vorwürfen
[url=http://www.ati.com]ATI[/url] hat nun offiziell Stellung zu den Vorwürfen der Versteckspiele bei ATis Texturfiltern genommen.
We have added intelligence to our filtering algorithm to increase performance without affecting image quality. As some people have discovered, it is possible to show differences between our filtering implementations for the RADEON 9800XT and RADEON X800. However, these differences can only be seen by subtracting before and after screenshots and amplifying the result. No-one has claimed that the differences make one implementation "better" than another.
If anyone does find any quality degradation as a result of this algorithm, they are invited to report it to ATI. If there is a problem, we will fix it.
Auch im Beyond3D Forum ist eine rege Diskussion entstanden, in Folge dessen auch einige interessante PDF Dateien auftauchten.[center][img]http://www.hardwareluxx.de/andreas/News/aticheat01.jpg[/img][/center]
[center][img]http://www.hardwareluxx.de/andreas/News/aticheat02.jpg[/img][/center]
[center][img]http://www.hardwareluxx.de/andreas/News/aticheat03.jpg[/img][/center]
Das komplette Statement:
There has been a lot of discussion about our trilinear filtering algorithms recently.
The objective of trilinear filtering is to make transitions between mipmap levels as near to invisible as possible. As long as this is achieved, there is no "right" or "wrong" way to implement the filtering.
Our algorithm for image analysis-based texture filtering techniques is patent-pending. It works by determining how different one mipmap level is from the next and then applying the appropriate level of filtering. It only applies this optimization to the typical case - specifically, where the mipmaps are generated using box filtering. Atypical situations, where each mipmap could differ significantly from the previous level, receive no optimizations. This includes extreme cases such as colored mipmap levels, which is why tests based on color mipmap levels show different results.
Just to be explicit: there is no application detection going on; this just illustrates the sophistication of the algorithm.
We encourage users to experiment with moving the texture preference slider from "Quality" towards "Performance" - you will see huge performance gains with no effect on image quality until the very end, and even then, the effect is hardly noticeable. We are confident that we give gamers the best image quality at every performance level.
Microsoft does set some standards for texture filtering and the company's WHQL process includes extensive image quality tests for trilinear filtering and mipmapping. CATALYST passes all these tests - and without application detection, which could be used if you wanted to get a lower-quality algorithm go undetected through the tests.
Finally, ATI takes image quality extremely seriously and we are confident that we set the bar for the whole industry. We don't undertake changes to our filtering algorithms lightly, and perform considerable on-line and off-line image analysis before implementing changes. This algorithm has been in public use for over a year in our RADEON 9600 series products, and we have not received any adverse comments on image quality in that time. If anyone does find any quality degradation as a result of this algorithm, they are invited to report it to ATI. If there is a problem, we will fix it.
Quellen und weitere Links
    KOMMENTARE ()
