ELSA stellt ATI FireGL V7100 vor
[url=http://www.elsa.com.tw]ELSA[/url] hat eine weitere Karte der ATI FireGL Serie vorgestellt. Die
ELSA ATI FireGL V7100 basiert auf dem PCI-Express Interface, hat einen Core Takt von 500 MHz und die 256 MB GDDR3 Speicher, die mit 256 Bit angebunden sind, arbeiten mit 1.000 MHz. Über Preise und Verfügbarkeit gibt es noch keine Informationen.
ELSA ATI FireGL V7100, powered by ATI FireGL V7100, offers the highest performance in the brand-new PCI-Express workstation series. ELSA ATI FireGL V7100 delivers the fastest, most accurate and superior quality graphics for professional OpenGL and Microsoft DirectX 9.0 applications. Featuring with the most rapid 256 MB GDDR3 memory, 256-bit memory interface, 16 rendering pixel pipelines and 6 vertex pipelines, ELSA ATI FireGL V7100 delivers the most remarkable geometry processing, realistic rendering and optimized application performance toward CAD and DCC designers. Graphics processor : | ATI FireGL V7100, Core Clock: 500 MHz |
Memory : | 256 MB 256-bit GDDR3 SDRAM, Memory Clock: 1000 MHz |
Bus system : | PCI-Express |
Graphics Features : | SMARTSHADER™ Technology - Programmable pixel and vertex shaders
- 16 textures per pass
- Pixel shaders up to 160 instructions with 32-bit floating point precision for each RGBA component
- Multiple render target support
- Shadow volume rendering acceleration
- High precision 10-bit per channel frame buffer support
SMOOTHVISION™ Technology - 2X/4X/6X anti-aliasing modes
- High performance adaptive algorithm with programmable sample patterns
- 2X/4X/8X/16X anisotropic filtering modes
- Adaptive algorithm with bi-linear (performance) and tri-linear (quality) options
HYPER Z™ Technology - 3-level Hierarchical Z-Buffer with early Z test
- Lossless Z-Buffer compression (up to 24:1)
- Fast Z-Buffer Clear
Hardware acceleration of the following: - Anti-aliased points and lines or full scene anti-aliasing (2X, 4X, 6X)
- 3D lines and triangles
- Stipple points
- Two-sided lighting
- Up to 8 light sources
- Directional and local lighting
- OpenGL overlay planes
- Occlusion culling
- 6 user defined clip planes
- OpenGL polymode functions
- 32-bit (24+8-bit stencil) Z Buffer
- Fast Z and color clears
- Full DX9 vertex shader support with 4 vertex units
- Quad-buffer stereo support
Graphics Standards : | OpenGL® 1.5 + extensions, OpenGL Shading Language, Microsoft® DirectX® 9.0, DX9 HLSL |
Standards : | DPMS, DDC2B, plug & play |
Connectors : | Dual DVI-I / 3D Stereo |
Operating systems : | Microsoft® Windows® XP, Microsoft® Windows® 2000 |
User Manual : | English Version |
Installation Guide : | English, German, Korean, Simplified Chinese and Traditional Chinese |
Accessories : | DVI-I to D-Sub adapter |
