Grafikkarten
Adrenalin 19.2.2 für Far Cry, Metro und Civilization VI
5
Der US-amerikanische Chip-Entwickler AMD hat jetzt passend zum kommenden Spiele-Release seinen Treiber aktualisiert. Spiele wie Far Cry New Dawn, Metro Exodus, Sid Meier’s Civilization VI und Crackdown 3 oder die neue Radeon VII werden jetzt offiziell unterstützt.
Folgende Probleme wurden beseitigt:
  • Using the Alt+Tab shortcut out of a fullscreen application or game may be slow or take longer than expected when using a display connected by DisplayPort.
  • Apply and Discard buttons may not appear in some areas of Radeon Overlay under the Radeon WattMan overclocking tab.
  • Radeon WattMan may fail to apply memory clock changes on AMD Radeon VII.
  • AMD Radeon VII may intermittently experience a system hang when attempting to perform a timeout detection and recovery on Windows 7 system configurations.
  • Radeon WattMan may display the incorrect max fan/temperature values for AMD Radeon VII.
  • Radeon WattMan may experience issues with changed values failing to save or load when multiple changes are applied at once.
  • AMD Radeon VII may experience intermittent system stability issues on some X399 motherboards.
  • Player Unknown’s Battlegrounds may intermittently experience an application crash when changing post-processing settings.
  • Radeon Settings may experience an application hang when loading the performance histogram in a game profile through game manager.
  • Update Notifications may sometimes incorrectly list the currently installed driver as an available upgrade.
  • Apex Legends may intermittently experience line corruption on AMD Radeon VII.
Folgende Probleme sind bekannt:
  • Battlefield V players may experience character outlines stuck on screen after being revived when the game is set to using DirectX 12 API.
  • Mouse lag or system slowdown is observed for extended periods of time with two or more displays connected and one display switched off.
  • FRTC may disappear from the Radeon Settings Global Graphics options on some system configurations when upgrading Radeon Software.
  • Radeon WattMan clock gauges may sometimes not change or appear incorrect when custom settings have been set on AMD Radeon VII.
  • Changes made in Radeon WattMan settings via Radeon Overlay may sometimes not save or take effect once Radeon Overlay is closed.
  • Fan speeds may remain elevated for longer periods than expected when using Tuning Control Auto Overclock in Radeon WattMan on AMD Radeon VII. A workaround is switching fan control to manual mode.
Ein Download des Treiber ist hier möglich.
Preise und Verfügbarkeit
Nicht verfügbar Nicht verfügbar Nicht verfügbar
Quellen und weitere Links KOMMENTARE (5)
