Equipped with a brand new design and the latest components, the Strider ST56F is the first SilverStone power supply to boost overall working efficiency of greater than 80%. Thanks to this high efficiency, the ST56F produces less wasted heat than typical power supplies and allows the included 120mm fan to operate at very low speeds, ensuring quietness at all times. This high output and efficiency are packed inside a simple yet stylish interior with compact dimensions for compatibility with nearly any ATX casing on the market. If high wattage power for dual core/dual video card processing and quietness are a priority, the Strider ST56F is the power supply for you.
