Corsair präsentiert zwei High-End Netzteile
Mit den beiden Modellen HX620W und HX520W hat [url=http://www.corsairmemory.com]Corsair[/url] seine ersten beiden Netzteile mit 520 bzw. 620 Watt vorgestellt. Ein modulares Stecksystem erlaubt eine übersichtliche Verkabelung und die dreifache +12V Schiene sowie 50 Ampere am 620 Watt bzw. 40 Ampere am 520 Watt Modell sorgen für eine ausreichende Leistung. Beide Netzteil sind ab sofort im Handel zusammen mit einer fünfjährigen Garantie erhältlich.
"Corsair has engineered a power supply that appeals to both enthusiasts as well as performance seekers who desire optimum performance, reliability and modular flexibility. During the development cycle, we carefully designed the HX power supplies to ensure our final product provided maximum performance with all the features demanded by enthusiasts"; so Don Lieberman, Chief Technology Officer bei Corsair
Corsair HX Series Features:
  • Supports the latest ATX12V v2.2 and EPS12V 2.91 standards and is backwards compatible with ATX12V 2.01 systems.
  • Guaranteed compatibility with dual-GPU configurations.
  • Double forward switching circuitry design offers high efficiency, up to 80% under wide load range.
  • Active Power Factor Correction with PF value=0.99 provides clean and reliable power to your system.
  • Universal AC input 90~264V automatically scans and detects the correct voltage. No more hassle of flipping that tiny red switch!
  • Ultra quiet 120mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
  • Guaranteed to deliver rated specifications at 50ºC.
  • Triple 12V Rails provide independent reliable power to the CPU, video card and other components with a combined rating of 50A (40A on 520W) maximum! Advanced circuitry design that automatically enables power sharing between the triple +12V rails in an event of overload on any single +12V rail.
  • Powerful +5Vsb rail with 3A rating.
  • Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components.
  • 105ºC rated industrial grade capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85ºC rated capacitors.
  • Enhanced modular flexible cables enable easier cable routing and increased airflow in the system.
  • Gold Plated connectors provide oxide free ultra low-resistance contact between the power supply and your critical components.
  • 8 Serial ATA connectors (4 on 520W).
  • Dimension: 5.9"(W) x 3.4"(H) X 5.9"(L); 150mm(W) x 86mm(H) x 150mm(L)
  • MTBF: 100,000 Hours
  • Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick.
    With the same legendary focus on performance and reliability that has produced countless award-winning products, Corsair has engineered the HX Series power supplies to stand up to the demands of the most robust PC systems. The HX Series is the ideal power supply for high performance PCs and gaming systems, audio/video workstations, and file servers.
    Corsair’s HX Series feature an enhanced modular cable solution, offering flexible cables for superior cable routing. The modular design eliminates cable clusters and optimizes the airflow inside the computer case to help keep the system cool. Available in 620Watt and 520Watt models, the HX Series efficiently delivers continuous fully rated output with solid triple +12V rails for a combined maximum output rating of 50Amp (40Amp on 520Watt) even at 50ºC ambient temperature. These output ratings exceed the requirements for even the most power hungry computers. Additionally, the HX620W and HX520W models offer native support for dual graphics card configurations and include two PCI-Express cables. The HX Series has been thoroughly tested and is compatible with today’s NVIDIA’s SLI and ATI’s Crossfire solutions.
    The HX Series provides 80%+ high efficiency and Active Power Factor Correction (PFC), ensuring the PSU generates minimal heat during operation using less electricity. In addition, the high quality thermally controlled double ball-bearing 120mm fan delivers excellent air flow with whisper quiet operation.
  • Quellen und weitere Links
      KOMMENTARE ()
