ASUSTeK, the worldwide leader of motherboards, today introduced the AI Proactive motherboard series, which includes four unique automatic features to enhance Intel’s latest 925X, 915P and 915G chipset platforms. The all-new motherboards also leveraged exclusive technologies to support native DDR2 600 and shorten memory latency.
Eine Übersicht der Modelle haben wir unter "Read More" zusamengestellt.[center][img]http://www.hardwareluxx.de/andreas/News/asusp5ad2-d_l.jpg[/img][/center][center]P5AD2 Deluxe[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5ad2-p_l.jpg[/img][/center]
[center]P5AD2 Premium[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gd1_l.jpg[/img][/center]
[center]P5GD1[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gd1-vm_l.jpg[/img][/center]
[center]P5GD1-VM[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gd2-d_l.jpg[/img][/center]
[center]P5GD2 Deluxe[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gd2-p_l.jpg[/img][/center]
[center]P5GD2 Premium[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gdc-d_l.jpg[/img][/center]
[center]P5GDC Deluxe[/center]
[center][img]http://www.hardwareluxx.de/andreas/News/asusp5gdc-v-d_l.jpg[/img][/center]
[center]P5GDC-V Deluxe [/center]
Stack Cool™ –Cooler overclocking and quieter operation
The patented Stack Cool technology utilizes a mini PCB stacked against the main PCB to conduct heat away from power components, resulting in a 10° Celsius temperature reduction. This fan-less design enables cooler overclocking, greater stability and longer system life without an extra noisy fan.
AI NOS™ – Boost performance when it's most needed
3D games and video editing demand large system resource. The patented AI NOS (Non-delay Overclocking System) technology intelligently detects system loading and automatically boosts performance for the most demanding tasks. Unlike other ”dynamic overclocking” mechanism that overclocks according to temperature, AI NOS accelerates exactly when it’s most needed.
WiFi-g™ – Onboard Access Point
WEP? SSID? Building a home WLAN used to be a hassle with confusing acronyms and cryptic menus. With WiFi-g, and its easy setup wizard, high-speed WLAN is a few clicks away. WiFi-g can serve as the access point or a wireless adapter for PCs to connect to existing WLAN. (Compliant to IEEE 802.11g 54Mbps data transfer.)
AI NET2™ –Diagnose LAN connection before entering OS
Network problems are often caused by bad cable connection. AI NET2 remotely detects cable connection the second you turn on the system, and reports back any faulty connections up to 100 meters at 1 meter accuracy.
DDR2 600 Native Support
Although Intel's 925X, 915P and 915G chipsets claimed to only support DDR2 400/533, ASUS engineers successfully unleashed their true potential. The ASUS AI Proactive series offers native DDR2 600, eliminating the bottleneck when overclocking both the CPU and memory. With current processors supporting 800MHz FSB, ASUS motherboards, the only solutions with native DDR2 600, will provide superior performance for the most demanding applications.
Hyper Path2 – Shorten Memory Latency
The Northbridge controls communication between the processor and memory. When the processor sends out memory related commands, the Northbridge provides a path for data transfer that includes various mechanisms to synchronize the CPU and memory. Unfortunately, these mechanisms cause data transfer delays, which are commonly known as “latency time between CPU and memory”.
The innovative ASUS Hyper Path2 significantly shortens the latency time between the CPU and memory on 925X and 915P chipsets, and improves memory performance without sacrificing stability. Enable both Hyper Path2 and Intel PAT (Performance Acceleration Technology) on the ASUS 925X based P5AD2 series to experience powerful computing never seen before.
[center][img]http://www.hardwareluxx.de/andreas/News/asus915925uebersicht.jpg[/img][/center]
