Model: LANPARTY UT RDX200 CF-DR
Chipset RDX 200+SB450
ATI Multi VPU support
CPU Socket-939 for AMD Athlon64 and Athlon64 FX51 to FX55+ and Athlon X2 processors
FSB 2000MTps Hyper Transport
Memory
128-bit Dual-channel memory architecture
4 184-pin DIMM sockets 4GB in max.
Supports unbuffered, single/double-side DDR-266/333/4001 DIMMs
Supports x8/x16, non-ECC and up to 512Mb DDR devices
Expansion Slots
2 PCI Express x16 slots
For MVP mode, 1 #16 slots operate as x8 ,another #16 slot operates as x8
For Single VGA mode, 1 #16 slot operates as x16, another #16 slot operates as x2
1 PCI Express#1 slot
3 x PCIs
Storage
1 Floppy port
2 parallel IDE ports with up to 133Mbps UltraDMA
4 SATA-1 IDE ports with up to 1.5Gbps
Promise PDC40719 supports 4 SATA-2 IDE ports with up to 3Gbps and RAID 0/1/0+1/5
USB 8 USB2.0 ports
Dual LAN
Marvell 88E8001 GbE PCI
Marvell 88E8053 GbE PCI-E
IEEE 1394 VT6307 with 2 IEEE1394 ports
Legacy IO IT8712F-A
Hardware Monitoring
CPU/System temperature sensing w/ overheating alarm
CPU overheating protection during system boot-up
12v/5v/3.3v/Vcore/Vbat/5Vsb voltages sensing
Support Linear fan control for CPU, CS, PWM
Back panel IO ports
1 x PS2 mouse, 1 x PS2 keyboard
1 x S/PDIF-In, 1 x S/PDIF-Out
2 USB2.0 ports, 1 x 1394 port
2 USB2.0 ports, 1 x RJ45 port
Other onboard connectors
1 USB header for 2 USB2.0 ports
1 2x5-pin header for IEEEE-1394 port
1 2x5-pin header for COM port
1 5x1-pin for IRDA header
1 5x1-pin for CIR
5 3-pin FAN connectors for CPU, Chipset, and Chassis,
KARAJAN audio header
Piezo-buzzer
5x1-pin SPDIF-In/Out header for optional optical interface
24-pin ATX & 2x4-pin ATX power connectors
Clear CMOS data header
Diag. LEDs w/header for FrontX
Standby LED, S3 LED
10x2-pin front panel headers (IDE LED, Power LED, Power switch, Reset button, PC speaker)
EZ-On and EZ-Touch switches for onboard power on and reset
Form Factor & PCB Size ATX, 305x240mm, 6 layers
BIOS features
4Mb flash ROM;
CMOS Reloaded
ACPI; PnP; Hotkey flash; Wake on Ring/LAN/USB/Keyboard and Mouse;
Manageability
DMI 2.0, WOL by PME; WOR by PME; PXE2 Boot
Excellent Over-clocking Capability
Voltage tuning Vdimm; Vnb; Vcore, Vht
1MHz frequency subtle tuningFFfsb
Adjustable CPU Multiplier
EMI Regulations FCC Class B, CE
Certifications AMD; XP WHQL
Accessories
Userfs Manual, Quick Installation Guide
KARAJAN audio module
2 Parallel IDE yellow round cable, 1 FDD yellow round cable
4 Serial IDE cables with S-ATA power cable
Driver CD
1 Floppy diskette for PDC40719 RAID
I/O shield with Rear panel sticker
KARAJAN Audio Module
RealTek ALC882 8CH audio CODEC
6 Audio Jacks; CD-In header; 5x2-pin Front audio select header
