[url=http://www.asuscom.de]ASUS[/url] hat heute seine NVIDIA nForce4 Mainboards mit 32 PCI-Express Lanes für den AMD Sockel 939 und Intel Sockel 775 vorgestellt. Sowohl das A8N32-SLI Deluxe als auch das P5N32-SLI Deluxe verfügen über 32 PCI-Express Lanes und erlauben somit im SLI Betrieb die volle 16 Lanes Anbindung für beide Grafikkarten.With exclusive technologies – daul x16 PCI Express SLI graphics, the 8-Phase Power design and fan-less cooling, the recently unveiled ASUS A8N32-SLI Deluxe and P5N32-SLI Deluxe motherboards deliver superior video performance, cool and quiet computing and stable and efficient power supply.
True Dual x16 SLI – More performance now. Even more later.
Unlike previous SLI-ready motherboards that come with two x8 PCI Express slots, two full-bandwidth, 16-lane PCI Express links ensure maximum graphics performance for next-generation GPUs and games. Compared with dual x8 SLI solutions, the dual x16 platform delivers up to 10% efficiency improvement.
Current 3D games have just begun to experience the performance limitations of current dual x8 SLI systems. The next generation games will present more detailed and higher resolution textures that stress the necessity for even higher graphics bandwidth.
8-Phase Power Design
With 8-Phase Power Design, power modules operate at 15°C lower than conventional power solutions to provide a cool computing environment. Lower temperature also results in lower fan speed for peace and quiet and better stability for overclocking.
8-Phase Power Design reduces input ripple current and output ripple voltage, keeping the CPU and power modules from high power stress to increase component lifespan. Furthermore, it has the advantage of quick transient response. It acts faster than 4-phase power designs to stabilize output current and voltage. This is especially critical when the CPU requires immediate current support when under heavy workload.
Fanless Design – Stack Cool 2 and Copper Heat Pipe
The Fanless Design brings effective and noiseless cooling to counter the heat generated by components. Watch movies, listen to music and play games, and enjoy the peace and quiet. System damages from fan failure is also a thing of the past.
The copper Heat Pipe directs heat generated by the chipsets to the heatsink near the back I/O ports, where it can be carried away by existing airflow, while Stack Cool 2 effectively transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for fast heat dissipation.
Optional fan bundle for water-cooling systems
The optional fan is specifically designed to provide sufficient airflow over the CPU power modules and chipset area when water-cooling and passive cooling are utilized, ensuring effective heat dissipation for the entire system.
*Optional fan is included in product package. Use only when water-cooling or passive CPU cooler is installed.
A8N32-SLI Deluxe and Corsair XMS-3500LL PRO
The new XMS-3500LL PRO is the industry’s first high-density memory that delivers blazing performance at CL2-1T low latency. Available in a matched pair of 1GB modules, it is shipped with SPD programmed at 2-3-2-6-1T for the AMD platform. The A8N32-SLI Deluxe and the memory are optimized for each other to reach maximum performance, and are validated for stability and compatibility.
Four models are currently available:
A8N32-SLI Deluxe
P5N32-SLI Deluxe
