DFI LanParty UT nForce4 SLI-DR Expert - Neuauflage des Rekordbrechers
[url=http://www.dfi.com.tw]DFI[/url] hat eine überarbeitete Version des DFI LanParty UT nForce4 SLI-DR vorgestellt. Neben dem neuen Layout wurden auch zahlreiche BIOS Optionen verbessert bzw. hinzugefügt und die Spannungsversorgung des DFI LanParty UT nForce4 SLI-DR Expert optimiert. Damit richtet DFI sein Mainboard noch stärker auf den Overclocker-Markt aus, auf dem die DFI nForce4 Serie fast alle Rekorde dominiert. Über die Verfügbarkeit oder den Preis gibt es bisher keine Informationen.
The LANParty UT nForce4 SLI-DR Expert features an improved design where the PCI-e x16 slots are placed wider apart to provide space for larger VGA coolers. This new layout allows for greater performance of the VGA cards. To facilitate the overclocking process, a convenient PCI-e configuration setting is incorporated in the BIOS of the LANParty UT nForce4 SLI-DR Expert to enable easy switching between SLI and non-SLI mode.
Furthermore, the n ew LANParty UT nForce4 SLI-DR Expert comes with 8-pin power connector (instead of 4) to provide more stable power source. A 4-phase PWN (increased from 3-phase) was implemented to offer better stability and smother performance. In addition, a smaller Karajan TM 8-channel audio card was incorporated to give more space for other larger devices. Finally, the new LANParty nForce4 SLI-DR Expert comes with even better overclocking range.
Consistent with the RockSolid TM performance of the LANParty series, the LANParty UT nForce4 SLI-DR Expert is made of 6 layers of PCB for enhanced stability, non-iron choke for increased heat absorption, 100% Japanese capacitors for best overclockability, low ESR solid capacitors to ensure safety, and magnetic-levitated fan to eliminate noise. Karajan TM 8-channel audio card is again an added bonus to maximize the game and video sound effect.
Finally, the LANParty UT nForce4 SLI-DR Expert comes with DFI's famous Genie BIOS and CMOS Reloaded TM , offering users a wide-range of tweaking features and customized setup that can be saved on-the-fly and accessed by a simple hot-key.
Quellen und weitere Links
    KOMMENTARE ()
