VIDIA nForce 590 SLI TM chipset
Based on NVIDIA's nForce4 ® SLI ™ media and communications processors (MCPs), the LANParty UT NF590 SLI-M2R offers users more control with extra headroom for maximum overclockability. Furthermore, NVIDIA SLI (Scalable Link Interface) technology coupled with compatible NVIDIA GeForce graphic cards can deliver up to two times the rock solid and blazing fast performance.
Support for SLI X16
In addition, the LANParty UT NF590 SLI-M2R comes with two true X16 PCI-e slots. This new architecture allows for faster data transfer at higher bandwidth, meaning users will see significant increases in graphics performance and enjoy enhanced 3D images.
Support for DDR2
With the market shifting to DDR2 memory, the LANParty UT NF590 SLI-M2R offers NVIDIA Certified SLI-Ready DDR2 Memory technology. Users will have a piece of mind with knowing their DFI motherboard and certain DDR2 memory are back up with certified compatibility. The LANParty UT NF590 SLI-M2R also supports advanced performance memory settings using Enhanced Performance Profiles (EPP), making it easier for the DIYer to spec and build their own systems.
First to use 5 phase digital PWM
DFI is the first in the industry to use 5 phase digital PWM, a technology prior only seen on server motherboards. Digital controllers eliminate the dangers of overheating and exploding capacitors, giving users a safer and better monitored control over the overclocking.
First copper heat sink fan
As with every LANParty motherboard launch, DFI incorporated a first-in-the-industry on the LANParty UT NF590 SLI-M2R motherboard by being the first to use copper heat sink fan. As a result, heat can be better absorbed using copper, giving users more room to push for extra overclocking.
Realtek ALC885
With greater gaming performance comes greater audio quality. DFI engineers incorporated the new Karajan with a new codec ~Realtek ALC885 on the LANParty UT NF590 SLI-M2R motherboard to bring users the ultimate audio experience suited for the ultimate gaming performance.
EZ Clear function
To facilitate the overclocking process, DFI engineers efficiently incorporated the EZ Clear feature to clear the BIOS with one simple touch of a button. In addition, on-board LEDs help users to pinpoint any trouble spots.
Genius BIOS and Cmos Reload
As is standard on all LANParty motherboards, the LANParty UT NF590 SLI-M2R comes with an extensive BIOS featuring a one-touch BIOS reset setting. The ultimate gamer and overclocker will enjoy tweaking and customizing their boards to squeeze out every ounce of overclockability on their DFI board.
New RAID function
The LANParty UT NF590 SLI-M2R supports the new RAID function with up to 8 SATAII connectors, giving users the freedom and mobility to connect their system to other external devices.
