Sound Blaster® Audigy® 4 Pro is an amazing fusion of Entertainment and Music Creation. Featuring ultra-high quality DACs and an External I/O Hub which provides 6 Stereo Inputs/6 Stereo Outputs, Sound Blaster Audigy 4 Pro enables amazingly clean recording of six channels at 24-bit/96kHz with low latency ASIO 2.0 support. Sound Blaster Audigy 4 Pro also comes with the all new Entertainment Center software and remote control unit, transforming your PC into a Entertainment Center with easy MP3 and movies playback and navigation. Audigy 4 Pro Processor
Advanced hardware accelerated digital effects processing | |||
32-bit digital processing, which maintains a theoretical 192 dB of dynamic range | |||
Patented 8-point interpolation that reduces distortion to inaudible levels | |||
64-voice hardware wavetable synthesizer | |||
Professional quality digital mixing and equalization |
High Definition Audio Quality for Playback and Recording
Playback of 64 audio channels, each at an arbitrary sample rate | |||
24-bit Analog-to-Digital conversion of analog inputs at 96 kHz sample rate | |||
24-bit Digital-to-Analog conversion of digital sources at 96 kHz to analog 7.1 speaker output | |||
24-bit Digital-to-Analog conversion of stereo digital sources at 192 kHz to stereo output | |||
16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96 kHz. | |||
Supports Sony/Philips Digital Interface (SPDIF) format of up to 24-bit/96 kHz quality. Selectable sampling rate of 44.1, 48 or 96 kHz | |||
Low latency multitrack recording with ASIO 2.0 support at 16-bit, 48 kHz and 24-bit, 96 kHz resolution. |
FireWire® (IEEE® 1394) Connectivity
Compliant with IEEE 1394a specification | |||
Supports data rates of 100, 200, and 400 Mbps | |||
Supports up to 63 FireWire (IEEE 1394) compatible devices in a daisy-chain configuration | |||
Supplies up to 3 Watts to FireWire (IEEE 1394) compatible devices |
Sound Blaster Audigy 4 Pro On-Board Connectors
Line level out (Front / Side / Rear / Center / Subwoofer) | |||
Digital CD Audio in | |||
Aux Audio in | |||
AD_Link 1 and AD_Link 2 connectors to connect with external I/O hub. | |||
Power connector |
Sound Blaster Audigy 4 Pro External I/O Hub Front / Rear Panel Connectors
Headphone Out (1/4" Stereo Jack) | |||
Line In 1 (1/4" Stereo Jack , shared with Mic In with Gain Control) | |||
Line In 2 (1/4" Stereo Jack) | |||
Line In 3 (2x RCA Jack) | |||
Optical SPDIF In/Out | |||
Coaxial SPDIF In/Out | |||
Digital Out for 5.1 support (6-channel SPDIF Output to Creative digital speakers) | |||
2x FireWire® (IEEE® 1394) ports | |||
MIDI In / Out | |||
Infra-red Receiver to communicate with Remote Control | |||
AD_Link 1 and AD_Link 2 connectors to connect with Audigy 4 Pro |
